Recent progress in unconstrained nonlinear optimization without derivatives, Mathematical Programming, vol.12, issue.1, 1997. ,
DOI : 10.1007/BF02614326
Towards a Complexity Theory of Randomized Search Heuristics: Ranking-Based Black-Box Complexity, CSR, ser. Lecture Notes in Computer Science, pp.15-28, 2011. ,
DOI : 10.1017/CBO9780511814075
Regret Bounds for Gaussian Process Bandit Problems, Conference Proceedings : AISTATS 2010, pp.273-280, 2010. ,
Numerical Optimization of Computer Models, pp.1995-1997, 1981. ,
Mutate large, but inherit small ! On the analysis of mutations in (1, ?)-ES with noisy fitness data, Proc. of the 5 th Conference on Parallel Problems Solving from Nature, pp.109-118, 1998. ,
Genetic algorithms in noisy environments, in machine learning: Special issue on genetic algorithms, 1988. ,
Local performance of the (1 + 1)-ES in a noisy environment, IEEE Transactions on Evolutionary Computation, vol.6, issue.1, pp.30-41, 2002. ,
DOI : 10.1109/4235.985690
Evolution strategies with cumulative step length adaptation on the noisy parabolic ridge, Natural Computing, vol.2, issue.2, 2006. ,
DOI : 10.1007/s11047-006-9025-5
Evolution strategies on noisy functions: How to improve convergence properties, " in Parallel Problem Solving From Nature, pp.9-14, 1994. ,
Genetic algorithms in noisy environments, Machine Learning, pp.101-120, 1988. ,
DOI : 10.1007/BF00113893
On Multiplicative Noise Models for Stochastic Search, Parallel Problem Solving From Nature, 2008. ,
DOI : 10.1007/978-3-540-87700-4_6
URL : https://hal.archives-ouvertes.fr/inria-00287725
On the adaptation of noise level for stochastic optimization, 2007 IEEE Congress on Evolutionary Computation, 2007. ,
DOI : 10.1109/CEC.2007.4424857
URL : https://hal.archives-ouvertes.fr/inria-00173224
CLOP: Confident Local Optimization for Noisy??Black-Box Parameter Tuning, Lecture Notes in Computer Science, H. J. van den, vol.7168, pp.146-157, 2011. ,
DOI : 10.1007/978-3-642-31866-5_13
URL : https://hal.archives-ouvertes.fr/hal-00750326
Handling expensive optimization with large noise, Proceedings of the 11th workshop proceedings on Foundations of genetic algorithms, FOGA '11, pp.61-68, 2011. ,
DOI : 10.1145/1967654.1967660
URL : https://hal.archives-ouvertes.fr/hal-00517157
Bandit-Based Estimation of Distribution Algorithms for Noisy Optimization: Rigorous Runtime Analysis, Proceedings of Lion4 (accepted), 2009. ,
DOI : 10.1007/978-3-642-13800-3_8
URL : https://hal.archives-ouvertes.fr/inria-00437140
Uncertainty handling CMA-ES for reinforcement learning, Proceedings of the 11th Annual conference on Genetic and evolutionary computation, GECCO '09, pp.1211-1218, 2009. ,
DOI : 10.1145/1569901.1570064
A probabilistic Theory of Pattern Recognition, 1997. ,
DOI : 10.1007/978-1-4612-0711-5
Efficient global optimization of expensive black-box functions, Journal of Global Optimization, vol.13, issue.4, pp.455-492, 1998. ,
DOI : 10.1023/A:1008306431147
An informational approach to the global optimization of expensive-to-evaluate functions, Journal of Global Optimization, vol.10, issue.5, p.26, 2008. ,
DOI : 10.1007/s10898-008-9354-2
URL : https://hal.archives-ouvertes.fr/hal-00354262
Stochastic Approximation of Minima with Improved Asymptotic Speed, The Annals of Mathematical Statistics, vol.38, issue.1, pp.191-200, 1967. ,
DOI : 10.1214/aoms/1177699070
ConsidérationsConsidérations`Considérationsà l'appui de la découverte de laplace, Comptes Rendus de l'Académie des Sciences, pp.309-324, 1853. ,
Sur les valeurs limites des integrales, Math Pure Appl, vol.19, pp.157-160 ,
On certain applications of algebraic continued fractions, 2002. ,
General Lower Bounds for Evolutionary Algorithms, 10 th International Conference on Parallel Problem Solving from Nature, 2006. ,
DOI : 10.1007/11844297_3
URL : https://hal.archives-ouvertes.fr/inria-00112820
Lower Bounds for Comparison Based Evolution Strategies Using VC-dimension and Sign Patterns, Algorithmica, vol.XVI, issue.2, pp.387-408, 2011. ,
DOI : 10.1007/s00453-010-9391-3
URL : https://hal.archives-ouvertes.fr/inria-00452791
Convergence results for the <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mo stretchy="false">(</mml:mo><mml:mn>1</mml:mn><mml:mo>,</mml:mo><mml:mi>??</mml:mi><mml:mo stretchy="false">)</mml:mo></mml:math>-SA-ES using the theory of <mml:math altimg="si2.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>??</mml:mi></mml:math>-irreducible Markov chains, Theoretical Computer Science, vol.334, issue.1-3, pp.35-69, 2005. ,
DOI : 10.1016/j.tcs.2004.11.017
Local and global order 3/2 convergence of a surrogate evolutionnary algorithm, Gecco, p.8, 2005. ,
Efficiency and mutation strength adaptation of the (mu/mui,lambda)-es in a noisy environment, Parallel Problem Solving from Nature, pp.39-48, 1917. ,
The Theory of Evolution Strategies, ser. Natural Computing Series, 2001. ,
Lower Rate of Convergence for Locating a Maximum of a Function, The Annals of Statistics, vol.16, issue.3, pp.1330-1334, 1988. ,
DOI : 10.1214/aos/1176350965
Stochastic Estimation of the Maximum of a Regression Function, The Annals of Mathematical Statistics, vol.23, issue.3, pp.462-466, 1952. ,
DOI : 10.1214/aoms/1177729392
Global optimization based on noisy evaluations: An empirical study of two statistical approaches, Journal of Physics: Conference Series, vol.135, p.17, 2008. ,
DOI : 10.1088/1742-6596/135/1/012100
URL : https://hal.archives-ouvertes.fr/hal-00278188
