New interface
Reports (Technical report)
3D-CE5.h: Merge candidate list for disparity compensated prediction
Thomas Guionnet 1 Laurent Guillo 1 Christine Guillemot 1
1 Sirocco - Analysis representation, compression and communication of visual data
Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : HEVC implements a candidate vector list for merge and skip modes. The construction of this list has been extensively studied in the JCT-VC group (see for instance JCTVC-G039). It has been shown in JCTVC-I0293 that it is possible to improve the HEVC coding performance by adding in the merge list copies of the first candidate shifted by an arbitrary offset. The same basis is considered in this document and applied to disparity compensation. A gain of 0.3 % is obtained on average on side views.
Document type :
Complete list of metadata
Cited literature [4 references]  Display  Hide  Download
https://hal.inria.fr/hal-00755747
Contributor : Laurent Guillo Connect in order to contact the contributor
Submitted on : Thursday, November 22, 2012 - 11:12:09 AM
Last modification on : Wednesday, October 26, 2022 - 8:14:03 AM
Long-term archiving on: : Saturday, December 17, 2016 - 1:32:09 PM
JCT3V-B0080.pdf
Identifiers
  • HAL Id : hal-00755747, version 1
Citation
Thomas Guionnet, Laurent Guillo, Christine Guillemot. 3D-CE5.h: Merge candidate list for disparity compensated prediction. [Technical Report] 2012. ⟨hal-00755747⟩
Share
Metrics
Record views
225
Files downloads
155
