New interface
Journal articles
Planar dynamics of a rigid body system with frictional impacts. II Qualitative analysis and numerical simulations
Zhen Zhao 1 Caishan Liu 2 Bernard Brogliato 3
3 BIPOP - Modelling, Simulation, Control and Optimization of Non-Smooth Dynamical Systems
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
Abstract : The objective of this paper is to implement and test the theory presented in a companion paper for the non-smooth dynamics exhibited in a bouncing dimer. Our approach revolves around the use of rigid body dynamics theory combined with constraint equations from the Coulomb's frictional law and the complementarity condition to identify the contact status of each contacting point. A set of impulsive differential equations based on Darboux-Keller shock dynamics is established that can deal with the complex behaviours involved in multiple collisions, such as the frictional effects, the local dissipation of energy at each contact point, and the dispersion of energy among various contact points. The paper will revisit the experimental phenomena found in Dorbolo et al. (Dorbolo et al. 2005 Phys. Rev. Lett. 95, 044101), and then present a qualitative analysis based on the theory proposed in part I. The value of the static coefficient of friction between the plate and the dimer is successfully estimated, and found to be responsible for the formation of the drift motion of the bouncing dimer. Plenty of numerical simulations are carried out, and precise agreements are obtained by the comparisons with the experimental results.
Document type :
Journal articles
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-00755926
Contributor : Bernard Brogliato Connect in order to contact the contributor
Submitted on : Thursday, November 9, 2017 - 4:13:25 AM
Last modification on : Thursday, January 20, 2022 - 5:30:55 PM
Long-term archiving on: : Saturday, February 10, 2018 - 12:54:54 PM
File
2267.full.pdf
Identifiers
Collections
Citation
Zhen Zhao, Caishan Liu, Bernard Brogliato. Planar dynamics of a rigid body system with frictional impacts. II Qualitative analysis and numerical simulations. Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, 2009, 465 (2107), pp.2267-2292. ⟨10.1098/rspa.2008.0520⟩. ⟨hal-00755926⟩
Share
Metrics
Record views
337
Files downloads
118
