Concurrent multiple impacts modelling, Proc. MIT Conf. on Computational Fluid and Solid Mechanics, pp.1836-1841, 2003. ,
DOI : 10.1016/B978-008044046-0.50450-4
URL : https://hal.archives-ouvertes.fr/inria-00424298
The Jamb (Self-Locking) Process in Three-Dimensional Collisions, Journal of Applied Mechanics, vol.65, issue.2, pp.417-423, 1998. ,
DOI : 10.1115/1.2789070
A New Look at an Old Problem: Newton???s Cradle, Journal of Applied Mechanics, vol.68, issue.4, pp.575-583, 2001. ,
DOI : 10.1115/1.1344902
1880 Etude géométrique sur les percussions et le choc des corps, Bulletin des Sciences Mathématiques et Astronomiques, deuxième série, pp.126-160 ,
DOI : 10.20537/nd1002013
Considérations sur le frottement de glissement, Nouv. Ann. Math, vol.20, pp.485-496, 1920. ,
Non-smooth thermo-mechanics, 2002. ,
Concepts for modeling impacts without friction, Acta Mechanica, vol.168, issue.1-2, pp.1-19, 2004. ,
DOI : 10.1007/s00707-004-0076-3
Multi-Body Impact Motion with Friction???Analysis, Simulation, and Experimental Validation, Journal of Mechanical Design, vol.115, issue.3, pp.412-422, 1993. ,
DOI : 10.1115/1.2919206
Impulse Correlation Ratio in Solving Multiple Impact Problems, Impacts in mechanical systems, pp.235-273, 2001. ,
DOI : 10.1007/3-540-45501-9_5
Impact With Friction, Journal of Applied Mechanics, vol.53, issue.1, pp.1-4, 1986. ,
DOI : 10.1115/1.3171712
1987 A continuous force model for the impact analysis of flexible multibody systems, Mech. Mach. Theory, vol.2287, pp.213-224 ,
Continuous contact force models for impact analysis in multibody systems, Nonlinear Dyn, vol.5, pp.193-207, 1994. ,
Stability properties of equilibrium sets of non-linear mechanical systems with dry friction and impact. Nonlinear Dyn, 2008. ,
The bouncing motion appearing in a robotics system with unilateral constraints. Nonlinear Dyn, pp.217-232, 2007. ,
The FEM analysis and approximate model for cylindrical joints with clearances, Mechanism and Machine Theory, vol.42, issue.2, pp.183-197, 2007. ,
DOI : 10.1016/j.mechmachtheory.2006.02.006
Theoretical analysis and numerical algorithm for frictionless multiple impacts in multibody systems. INRIA research report, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00204018
In press. Frictionless multiple impacts in multibody systems. II. Numberical algorithm and simulation results ,
Some numerical methods in multibody dynamics: application to granular materials, Eur. J. Mech. A. Solids, vol.13, pp.93-114, 1994. ,
Multibody dynamics with unilateral contacts. Wiley Series in Nonlinear Science, 1996. ,
Contact law effects on wave propagation in particulate materials using distinct element modeling, International Journal of Non-Linear Mechanics, vol.28, issue.2, pp.251-265, 1993. ,
DOI : 10.1016/0020-7462(93)90061-O
Elastoplastic phenomena in multibody impact dynamics, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.50-51, pp.6874-6890, 2006. ,
DOI : 10.1016/j.cma.2005.08.011
Numerical and experimental investigation of radial impacts on a half-circular plate, Multibody System Dynamics, vol.9, issue.3, pp.265-281, 2003. ,
DOI : 10.1023/A:1022991831100
Swerve During Three-Dimensional Impact of Rough Rigid Bodies, Journal of Applied Mechanics, vol.61, issue.3, pp.605-611, 1994. ,
DOI : 10.1115/1.2901502
Chain Reaction From Impact on Coaxial Multibody Systems, Journal of Applied Mechanics, vol.67, issue.3, pp.632-635, 2000. ,
DOI : 10.1115/1.1309541
Chain reaction from impact on aggregate of elasto-plastic ???rigid??? bodies, International Journal of Impact Engineering, vol.28, issue.3, pp.291-302, 2003. ,
DOI : 10.1016/S0734-743X(02)00033-7
The theoretical analysis of three balls systems with multiple impacts, Chinese, pp.674-681, 2006. ,
Spring-dashpot models for the dynamics of a radially rotating beam with impact, Journal of Sound and Vibration, vol.142, issue.3, pp.515-525, 1990. ,
DOI : 10.1016/0022-460X(90)90665-M
