Frictionless multiple impacts in multibody systems. II. Numerical algorithm and simulation results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences Année : 2009
Part I of this paper develops a framework that is an extension of the Darboux-Keller shock dynamics towards frictionless multiple impacts between bodies composed of rateindependent materials. A numerical algorithm is proposed in this paper, in which the impulsive differential equation is discretized with respect to the primary impulse corresponding to the contact with the highest potential energy, and the integration step size is estimated at the momentum level. This algorithm respects the energetic constraints and avoids the stiff ordinary differential equation problem arising by directly using the compliant model. The well-known example of Newton's cradle, as well as Bernoulli's system, is used to illustrate the developments.
Proc._R._Soc._A-2009-Liu-1-23DP2.pdf (918.25 Ko) Télécharger le fichier
hal-00755948 , version 1 (22-11-2012)
Caishan Liu, Zhen Zhao, Bernard Brogliato. Frictionless multiple impacts in multibody systems. II. Numerical algorithm and simulation results. Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, 2009, 465 (2101), pp.1-23. ⟨10.1098/rspa.2008.0079⟩. ⟨hal-00755948⟩
153 Consultations
281 Téléchargements
