Detection of Abrupt Changes: Theory and Application, 1993. ,
URL : https://hal.archives-ouvertes.fr/hal-00008518
A Volterra filter for neuronal spike detection ALIEN Inria, Research Report, 2008. ,
Algebraic change-point detection, Applicable Algebra in Engineering, Communication and Computing, vol.83, issue.2, pp.131-143, 2010. ,
DOI : 10.1007/s00200-010-0119-z
URL : https://hal.archives-ouvertes.fr/inria-00439226
A delay estimation approach to change-point detection, MED08, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00179775
Frequency change-point detection in physiological signals : an algebraic approach, Int. J. on Sci. and Tech. of Aut. Cont. & Comp. Eng, vol.2, issue.1, pp.456-468, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00308474
Spike detection and sorting: Combining algebraic differentiations with ica, " in Independent Component Analysis and Signal Separation, 8th Int, Conf, pp.475-482, 2009. ,
An Algebraic Method for Eye Blink Artifacts Detection in Single Channel EEG Recordings, 17th Int. Conf. on Biomagnetism, pp.175-178, 2010. ,
DOI : 10.1007/978-3-642-12197-5_38
URL : https://hal.archives-ouvertes.fr/hal-00518627
Prediction of epileptic seizures, The Lancet Neurology, vol.1, issue.1, pp.22-30, 2002. ,
DOI : 10.1016/S1474-4422(02)00003-0
Event-related eeg/meg synchronization and desynchronization: basic principles Fault diagnosis on a magnetically supported plate, Clinical Neurophysiology, vol.11010, issue.11, pp.1842-1857, 1999. ,
Fault diagnosis without a priori model, Systems and Control Letters, vol.61, issue.2, pp.316-321, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00650811
Fault detection and diagnosis in chemical and petrochemical processes, 1978. ,
Detection of structural damage through changes in frequency: a review, Engineering Structures, vol.19, issue.9, pp.718-723, 1997. ,
DOI : 10.1016/S0141-0296(96)00149-6
Process analysis by statistical methods, 1970. ,
An algebraic framework for linear identification, ESAIM: COCV. SMAI, pp.151-168, 2003. ,
DOI : 10.1051/cocv:2003008
URL : http://www.numdam.org/article/COCV_2003__9__151_0.pdf
Algebraic Parameter Estimation of Damped Exponentials, EUSIPCO, pp.965-969, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00179732
Parameter estimation for signals described by differential equations, Applicable Analysis, vol.26, issue.1, pp.29-52, 2009. ,
DOI : 10.1109/MED.2008.4602161
Algebraic parameter estimation of a biased sinusoidal waveform signal from noisy data, Sysid 2012, 16th IFAC Symposium on System Identification, 2012. ,
DOI : 10.3182/20120711-3-BE-2027.00393
URL : https://hal.archives-ouvertes.fr/hal-00685067
