Conference papers
Fault diagnosis on a magnetically supported plate
Abstract : A model-based online fault-diagnosis scheme for an electromagnetically supported plate is presented as an example of a nonlinear and open-loop unstable system. First, residuals for sensor as well as for actuator faults are generated using algebraic derivative estimators. Then, the robust detection and isolation of step-like sensor and actuator faults is presented. The performance of the proposed algorithms is illustrated by experimental results.
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-00756109
Contributor : Mamadou Mboup Connect in order to contact the contributor
Submitted on : Thursday, November 22, 2012 - 3:10:09 PM
Last modification on : Wednesday, September 7, 2022 - 8:14:05 AM
Long-term archiving on: : Saturday, February 23, 2013 - 3:45:18 AM
File
faultDiag.pdf
Identifiers
  • HAL Id : hal-00756109, version 1
Collections
Citation
Lothar Kiltz, Mamadou Mboup, Joachim Rudolph. Fault diagnosis on a magnetically supported plate. 1st International Conference Systems and Computer Science, Aug 2012, Lille, France. ⟨hal-00756109⟩
Share
Metrics
Record views
160
Files downloads
152
