Learning Latent Factor Models of Human Travel - Archive ouverte HAL Access content directly
Conference Papers Year : 2012
This paper describes probability models for human travel, using latent factors learned from data. The latent factors represent interpretable properties: travel distance cost, desirability of destinations, and affinity between locations. Individuals are clustered into distinct styles of travel. The latent factors combine in a multiplicative manner, and are learned using Maximum Likelihood. The resulting models exhibit significant improvements in predictive power over previous methods, while also using far fewer parameters than histogram-based methods. The method is demonstrated on travel data from two sources: geotags from a social image sharing site (Flickr), and GPS tracks from Shanghai taxis.
latentTravel-tn.png (17.79 Ko) Télécharger le fichier Fichier principal
paper.pdf (488.38 Ko) Télécharger le fichier
Format : Figure, Image
Dates and versions
hal-00756192 , version 1 (22-11-2012)
Identifiers
  • HAL Id : hal-00756192 , version 1
Cite
Michael Guerzhoy, Aaron Hertzmann. Learning Latent Factor Models of Human Travel. NIPS Wokshop on Social Network and Social Media Analysis: Methods, Models and Applications, Dec 2012, Lake Tahoe, Nevada, United States. ⟨hal-00756192⟩
540 View
188 Download
Share
