Existence and Uniqueness of Solutions for Non-Autonomous Complementarity Dynamical Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Convex Analysis Année : 2010
This paper deals with the well-posedness of a class of complementarity dynamical systems. Both the linear and the nonlinear cases are treated, and the systems are non-autonomous. A specific "inputoutput" property is used to perform a change of state vector which allows one to transform the complementarity dynamics into a perturbed Moreau's sweeping process. Then the results obtained elsewhere by Thibault and his co-workers [16, 15, 40] on the well-posedness of the sweeping process are used. Absolutely continuous as well as bounded variation solutions (with state jumps) are examined in this work.
BBLT.pdf (297.34 Ko) Télécharger le fichier
hal-00756226 , version 1 (03-11-2017)
  • HAL Id : hal-00756226 , version 1
Bernard Brogliato, Lionel Thibault. Existence and Uniqueness of Solutions for Non-Autonomous Complementarity Dynamical Systems. Journal of Convex Analysis, 2010, 17 (3&4), pp.961-990. ⟨hal-00756226⟩
499 Consultations
802 Téléchargements
