Numerical Methods for Nonsmooth Dynamical Systems, ser. Lecture Notes in Applied and Computational Mechanics, 2008. ,
Formulation and well-posedness of the dynamics of rigid-body systems with perfect unilateral constraints, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.359, issue.1789, pp.2327-2346, 2001. ,
DOI : 10.1098/rsta.2001.0854
Dynamical Systems With Active Singularities of Elastic Type: A Modeling and Controller Synthesis Framework, IEEE Transactions on Automatic Control, vol.52, issue.1, pp.39-55, 2007. ,
DOI : 10.1109/TAC.2006.887899
TRACKING CONTROL OF COMPLEMENTARITY LAGRANGIAN SYSTEMS, International Journal of Bifurcation and Chaos, vol.296, issue.06, pp.1839-1866, 2005. ,
DOI : 10.1109/JRA.1987.1087120
URL : https://hal.archives-ouvertes.fr/inria-00070619
Fast algebraic impact times estimation for a linear system subject to unilateral constraint, 2007 46th IEEE Conference on Decision and Control, pp.12-14, 2007. ,
DOI : 10.1109/CDC.2007.4434023
Dissipative Systems Analysis and Control, Theory and Applications, 2007. ,
DOI : 10.1007/978-1-84628-517-2
URL : https://hal.archives-ouvertes.fr/hal-00821748
On the control of finite-dimensional mechanical systems with unilateral constraints, IEEE Transactions on Automatic Control, vol.42, issue.2, pp.200-215, 1997. ,
DOI : 10.1109/9.554400
Absolute stability and the Lagrange???Dirichlet theorem with monotone multivalued mappings, Systems & Control Letters, vol.51, issue.5, pp.343-353, 2004. ,
DOI : 10.1016/j.sysconle.2003.09.007
URL : https://hal.archives-ouvertes.fr/inria-00071792
Finite-Dimensional Variational Inequalities and Complementarity Problems, ser. Springer Series in Operations Research, 2003. ,
Haptic Display of Constrained Dynamic Systems via Admittance Displays, IEEE Transactions on Robotics, vol.23, issue.1, pp.101-111, 2007. ,
DOI : 10.1109/TRO.2006.886837
Trajectory tracking for a particle in elliptical billiards, International Journal of Control, vol.24, issue.2, pp.189-213, 2008. ,
DOI : 10.1103/PhysRevE.64.026212
Set valued force laws: Dynamics of non-smooth systems, Lecture Notes in Applied Mechanics, 2001. ,
DOI : 10.1007/978-3-540-44479-4
Concepts for modeling impacts without friction, Acta Mechanica, vol.168, issue.1-2, pp.1-19, 2004. ,
DOI : 10.1007/s00707-004-0076-3
URL : http://www.zfm.ethz.ch/~glocker/publicationpdf/journal publications/bw_2004_actamechanica.pdf
Time-optimal control for a robotic contour following problem, IEEE Journal on Robotics and Automation, vol.4, issue.2, pp.140-149, 1988. ,
DOI : 10.1109/56.2077
Bang-bang impact control using hybrid impedance/time-delay control, IEEE/ASME Trans. Mechatron, vol.8, issue.2, pp.272-277, 2003. ,
Stability properties of equilibrium sets of non-linear mechanical systems with dry friction and impact, Nonlinear Dynamics, vol.43, issue.4, pp.551-583, 2008. ,
DOI : 10.1142/5442
UNIFORM CONVERGENCE OF MONOTONE MEASURE DIFFERENTIAL INCLUSIONS: WITH APPLICATION TO THE CONTROL OF MECHANICAL SYSTEMS WITH UNILATERAL CONSTRAINTS, International Journal of Bifurcation and Chaos, vol.7, issue.05, pp.1435-1457, 2008. ,
DOI : 10.1007/BFb0109998
Stability and Convergence of Mechanical Systems with Unilateral Constraints, ser. Lecture Notes in Applied and Computational Mechanics, 2008. ,
A unified variational model for the dynamics of perfect unilateral constraints, European Journal of Mechanics - A/Solids, vol.17, issue.5, pp.819-842, 1998. ,
DOI : 10.1016/S0997-7538(98)80007-7
Feedback stabilization and tracking of constrained robots, IEEE Transactions on Automatic Control, vol.33, issue.5, pp.419-426, 1988. ,
DOI : 10.1109/9.1220
Asymptotic tracking of periodic trajectories for a simple mechanical system subject to nonsmooth impacts, IEEE Transactions on Automatic Control, vol.46, issue.7, pp.1122-1126, 2001. ,
DOI : 10.1109/9.935068
Exponential and BIBS stabilisation of one degree of freedom mechanical systems subject to single non-smooth impacts, IEE Proceedings - Control Theory and Applications, vol.148, issue.2, pp.147-155, 2001. ,
DOI : 10.1049/ip-cta:20010366
Dynamic position feedback stabilisation of multidegrees-of-freedom linear mechanical systems subject to nonsmooth impacts, IEE Proceedings - Control Theory and Applications, vol.148, issue.6, pp.488-496, 2001. ,
DOI : 10.1049/ip-cta:20010713
Unilateral Contact and Dry Friction in Finite Freedom Dynamics, Nonsmooth Mechanics and Applications, CISM Courses and Lectures, 1988. ,
DOI : 10.1007/978-3-7091-2624-0_1
Control of contact problem in constrained Euler-Lagrange systems, Proceedings of the 36th IEEE Conference on Decision and Control, pp.1595-1599, 2001. ,
DOI : 10.1109/CDC.1997.657625
An Experimental Study of Planar Impact of a Robot Manipulator, IEEE/ASME Transactions on Mechatronics, vol.9, issue.1, pp.123-128, 2004. ,
DOI : 10.1109/TMECH.2004.823888
Impact stabilizing controller for hydraulic actuators with friction: Theory and experiments, Control Engineering Practice, vol.14, issue.12, pp.1423-1433, 2006. ,
DOI : 10.1016/j.conengprac.2005.10.007
Adaptive manipulator control: A case study, IEEE Transactions on Automatic Control, vol.33, issue.11, pp.995-1003, 1988. ,
DOI : 10.1109/9.14411
Modeling and control of impact in mechanical systems: theory and experimental results, IEEE Transactions on Automatic Control, vol.44, issue.2, pp.294-309, 1999. ,
DOI : 10.1109/9.746255
Experimental Validation of Contact Dynamics Simulation of Constrained Robotic Tasks, The International Journal of Robotics Research, vol.19, issue.12, pp.1203-1217, 2000. ,
DOI : 10.1177/02783640022068039
A Theoretical and Experimental Investigation of Impact Control for Manipulators, The International Journal of Robotics Research, vol.48, issue.11, pp.351-365, 1993. ,
DOI : 10.1115/1.3427095
Experimental study of contact transition control incorporating joint acceleration feedback, IEEE/ASME Transactions on Mechatronics, vol.5, issue.3, pp.292-301, 2000. ,
DOI : 10.1109/3516.868921
