New interface
Journal articles
Predictive value of modeled AUC(AFP-hCG), a dynamic kinetic parameter characterizing serum tumor marker decline in patients with nonseminomatous germ cell tumor.
Abstract : OBJECTIVE: The early decline profile of alpha-fetoprotein (AFP) and human chorionic gonadotropin (hCG) in patients with nonseminomatous germ cell tumors (NSGCT) treated with chemotherapy may be related to the risk of relapse. We assessed the predictive values of areas under the curve of hCG (AUC(hCG)) and AFP (AUC(AFP)) of modeled concentration-time equations on progression-free survival (PFS). METHODS: Single-center retrospective analysis of hCG and AFP time-points from 65 patients with IGCCCG intermediate-poor risk NSGCT treated with 4 cycles of bleomycin-etoposide-cisplatin (BEP). To determine AUC(hCG) and AUC(AFP) for D0-D42, AUCs for D0-D7 were calculated using the trapezoid rule and AUCs for D7-D42 were calculated using the mathematic integrals of equations modeled with NONMEM. Combining AUC(AFP) and AUC(hCG) enabled us to define 2 predictive groups: namely, patients with favorable and unfavorable AUC(AFP-hCG). Survival analyses and ROC curves assessed the predictive values of AUC(AFP-hCG) groups regarding progression-free survival (PFS) and compared them with those of half-life (HL) and time-to-normalization (TTN). RESULTS: Mono-exponential models best fit the patterns of marker decreases. Patients with a favorable AUC(AFP-hCG) had a significantly better PFS (100% vs 71.5%, P = .014). ROC curves confirmed the encouraging predictive accuracy of AUC(AFP-hCG) against HL or TTN regarding progression risk (ROC AUCs = 79.6 vs 71.9 and 70.2 respectively). Because of the large number of patients with missing data, multivariate analysis could not be performed. CONCLUSION: AUC(AFP-hCG) is a dynamic parameter characterizing tumor marker decline in patients with NSGCT during BEP treatment. Its value as a promising predictive factor should be validated.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00756356
Contributor : Benjamin Ribba Connect in order to contact the contributor
Submitted on : Thursday, November 22, 2012 - 7:19:21 PM
Last modification on : Monday, July 4, 2022 - 10:29:56 AM
Identifiers
Citation
Benoit You, Ludivine Fronton, Helen Boyle, Jean-Pierre Droz, Pascal Girard, et al.. Predictive value of modeled AUC(AFP-hCG), a dynamic kinetic parameter characterizing serum tumor marker decline in patients with nonseminomatous germ cell tumor.. Urology, 2010, 76 (2), pp.423-9.e2. ⟨10.1016/j.urology.2010.02.049⟩. ⟨hal-00756356⟩
Share
Metrics
Record views
184
