Logico-Numerical Max-Strategy Iteration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Strategy iteration methods are used for solving fixed point equations. It has been shown that they improve precision in static analysis based on abstract interpretation and template abstract domains, e.g. intervals, octagons or template polyhedra. However, they are limited to numerical programs. In this paper, we propose a method for applying max-strategy iteration to logico-numerical programs, i.e. programs with numerical and Boolean variables, without explicitly enumerating the Boolean state space. The method is optimal in the sense that it computes the least fixed point w.r.t. the abstract domain; in particular, it does not resort to widening. Moreover, we give experimental evidence about the efficiency and precision of the approach.
paper.pdf (242.47 Ko) Télécharger le fichier
hal-00756833 , version 1 (23-11-2012)
  • HAL Id : hal-00756833 , version 1
Peter Schrammel, Pavle Subotic. Logico-Numerical Max-Strategy Iteration. Verification, Model Checking, and Abstract Interpretation, Jan 2013, Rome, Italy. pp.414-433. ⟨hal-00756833⟩
277 Consultations
396 Téléchargements
