Program Analysis Scenarios In Rascal
Rascal is a meta programming language focused on the implementation of domain-specific languages and on the rapid construction of tools for software analysis and software transformation. In this paper we focus on the use of Rascal for software analysis. We illustrate a range of scenarios for building new software analysis tools through a number of examples, including one showing integration with an existing Maude-based analysis. We then focus on ongoing work on alias analysis and type inference for PHP, showing how Rascal is being used, and sketching a hypothetical solution in Maude. We conclude with a high-level discussion on the commonalities and differences between Rascal and Maude when applied to program analysis.
