New interface
Conference papers
Energy-efficient Relay Selection Schemes for Contention-based Geographic Forwarding
Ibrahim Amadou 1 Anis Ouni 1 Hervé Rivano 1 Fabrice Valois 1
1 URBANET - Réseaux capillaires urbains
Inria Grenoble - Rhône-Alpes, CITI - CITI Centre of Innovation in Telecommunications and Integration of services
Abstract : Contention-based Geographic Forwarding (CGF) has emerged recently as an energy-efficient communication proto- col to improve the wireless sensor networks lifetime. By exploiting the wireless broadcast advantage and node spatial diversity, it mitigates the effect of varying channel condition and node unavailability. The main contributions are based on classical relay selection scheme such as most forward within radius. However, this relay selection scheme performs poorly under real radio environments because it tends to forward packets on unreliable link, which leads to high expected number of retransmissions in each hop and an important number of duplicated packets. In this paper, we investigate the performance of several relay selection schemes. First, extensive simulations are proposed to evaluate their performance locally in terms of packet delivery ratio and duplicated packets. Then, we extend the work in multi- hop wireless networks and evaluate their performance in term of energy. To highlight their gain, we propose a smart solution obtained by linear programming. Based on the intelligent relay selection scheme, we develop a new solution, Furthest Forward within Reliable neighbors (FFRe), which tries to save more energy than the most efficient relay selection schemes.
Document type :
Conference papers
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-00757274
Contributor : Hervé Rivano Connect in order to contact the contributor
Submitted on : Monday, November 26, 2012 - 3:36:30 PM
Last modification on : Friday, May 13, 2022 - 3:16:02 PM
Long-term archiving on: : Wednesday, February 27, 2013 - 3:45:18 AM
File
WirelessDay.pdf
Identifiers
  • HAL Id : hal-00757274, version 1
Collections
Citation
Ibrahim Amadou, Anis Ouni, Hervé Rivano, Fabrice Valois. Energy-efficient Relay Selection Schemes for Contention-based Geographic Forwarding. IFIP Wireless Days 2012, Nov 2012, Dublin, Ireland. ⟨hal-00757274⟩
Share
Metrics
Record views
211
Files downloads
250
