VCM: The Vector-Based Coloring Method for Grid Wireless AdHhoc and Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cédric Adjih
Ichrak Amdouni
  • Fonction : Auteur
  • PersonId : 898418
Pascale Minet
Graph coloring is used in wireless ad hoc and sensor networks to optimize network resources: bandwidth and energy. Nodes access the medium according to their color. It is the responsibility of the coloring algorithm to ensure that interfering nodes do not have the same color. In this paper, we focus on wireless ad hoc and sensor networks with grid topologies. How does a coloring algorithm take advantage of the regularity of grid topology to provide an optimal periodic coloring, that is a coloring with the minimum number of colors? We propose the Vector-Based Coloring Method, denoted VCM, a new method that is able to provide an optimal periodic coloring for any radio transmission range and for any h-hop coloring, h >=1. In h-hop coloring, no nodes that are p-hop away, with 1<= p <= h use the same color. This method consists in determining at which grid nodes a color can be reproduced without creating interferences between these nodes while minimizing the number of colors used. We compare the number of colors provided by VCM with the number of colors obtained by a distributed coloring algorithm with line and column priority assignments. Finally, we discuss the applicability of this method to a real wireless network.
Fichier non déposé
hal-00757324 , version 1 (26-11-2012)
Cédric Adjih, Ichrak Amdouni, Pascale Minet. VCM: The Vector-Based Coloring Method for Grid Wireless AdHhoc and Sensor Networks. MSWIM 2012 - 15th ACM International Conference on Modeling, Analysis, Oct 2012, Paphos, Cyprus. pp.213-222, ⟨10.1145/2387238.2387275⟩. ⟨hal-00757324⟩
173 Consultations
0 Téléchargements
