V. Andrieu, L. Praly, and A. , Homogeneous Approximation, Recursive Observer Design, and Output Feedback, SIAM Journal on Control and Optimization, vol.47, issue.4, pp.1814-1850, 2008.
DOI : 10.1137/060675861
URL : https://hal.archives-ouvertes.fr/hal-00362707
G. Bartolini, A. Pisano, E. Punta, and E. Usai, A survey of applications of second-order sliding mode control to mechanical systems, International Journal of Control, vol.76, issue.9-10, pp.875-892, 2003.
DOI : 10.1080/0020717031000099010
F. J. Bejarano and &. L. Fridman, High order sliding mode observer for linear systems with unbounded unknown inputs, International Journal of Control, vol.15, issue.9, pp.1920-1929, 2010.
DOI : 10.1109/TAC.1987.1104530
S. P. Bhat and D. S. Bernstein, Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000.
DOI : 10.1137/S0363012997321358
E. Cruz-zavala, J. A. Moreno, and L. Fridman, Uniform Second-Order Sliding Mode Observer for mechanical systems, 2010 11th International Workshop on Variable Structure Systems (VSS), pp.14-19, 2010.
DOI : 10.1109/VSS.2010.5544656
S. V. Drakunov, Block Control Principle I, Automation and Remote Control, pp.601-609, 1990.
C. Ebenbauer and F. Allgöwer, Analysis and design of polynomial control systems using dissipation inequalities and sum of squares, Computers & Chemical Engineering, vol.30, issue.10-12, pp.1590-1602, 2006.
DOI : 10.1016/j.compchemeng.2006.05.014
D. Efimov, Uniting global and local controllers under acting disturbances, Automatica, vol.42, issue.3, pp.489-495, 2006.
DOI : 10.1016/j.automatica.2005.11.003
R. Engel and G. Kreisselmeier, A continuous-time observer which converges in finite time, IEEE Transactions on Automatic Control, vol.47, issue.7, p.12021204, 2002.
DOI : 10.1109/TAC.2002.800673
A. Ferrara and &. L. Giacomini, On multi-input backstepping design with second order sliding modes for a class of uncertain nonlinear systems, International Journal of Control, vol.71, issue.5, pp.767-788, 1998.
DOI : 10.1080/002071798221560
A. F. Filippov, Differential equations with discontinuous right-hand side, 1988.
DOI : 10.1090/trans2/042/13
V. T. Haimo, Finite Time Controllers, SIAM Journal on Control and Optimization, vol.24, issue.4, pp.760-770, 1986.
DOI : 10.1137/0324047
Y. Hong and Z. Jiang, Finite-Time Stabilization of Nonlinear Systems With Parametric and Dynamic Uncertainties, IEEE Transactions on Automatic Control, vol.51, issue.12, pp.1950-1956, 2006.
DOI : 10.1109/TAC.2006.886515
S. A. Krasnova, T. G. Sirotina, and V. A. , Utkin, A structural approach to robust control, Automation and Remote Control, pp.1639-1666, 2011.
A. Levant, Homogeneity approach to high-order sliding mode design, Automatica, vol.41, issue.5, pp.823-830, 2005.
DOI : 10.1016/j.automatica.2004.11.029
A. Levant, Principles of 2-sliding mode design, Automatica, vol.43, issue.4, pp.576-586, 2007.
DOI : 10.1016/j.automatica.2006.10.008
M. James, Finite time observers and observability, 29th IEEE Conference on Decision and Control, pp.770-771, 1990.
DOI : 10.1109/CDC.1990.203692
E. Moulay and W. Perruquetti, Finite-Time Stability and Stabilization: State of the Art, Lecture Notes in Control and Information Sciences, vol.334, pp.23-41, 2006.
DOI : 10.1007/11612735_2
Y. Orlov, Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2005.
DOI : 10.1137/S0363012903425593
Y. Orlov, Discontinous systems: Lyapunov analysis and robust synthesis under uncertainty conditions, 2009.
A. Polyakov and A. Poznyak, Lyapunov function design for finite-time convergence analysis: ???Twisting??? controller for second-order sliding mode realization, Automatica, vol.45, issue.2, pp.444-448, 2009.
DOI : 10.1016/j.automatica.2008.07.013
T. Raff and F. Allgöwer, An Observer that Converges in Finite Time Due to Measurement-based State Updates, IFAC World Congress, pp.2693-2695, 2008.
DOI : 10.3182/20080706-5-KR-1001.00453
V. I. Utkin, Sliding Modes in Control Optimization, 1992.
DOI : 10.1007/978-3-642-84379-2
