The crust and the beta-skeleton: Combinatorial curve reconstruction, GMIP Proceedings, vol.60, issue.2 1, pp.125-135, 1998. ,
Voronoi-based variational reconstruction of unori- c 2011 The Author(s) ,
1 -sparse reconstruction of sharp point set surfaces, ACM Trans. on Graphics, vol.29, issue.5 1, pp.1-12, 2010. ,
Geometric Inference for Measures based on Distance Functions, 2009. ,
Curve reconstruction from noisy samples, Proc. of the Conf. on Comp, pp.302-311, 2003. ,
Computational Geometry Algorithms Library ,
Simultaneous curve simplification, Journal of Geographical Systems, vol.11, issue.3, pp.273-289, 2009. ,
Exoskeleton: Curve network abstraction for 3d shapes, Comput. Graph, vol.35, issue.2, pp.112-121, 2011. ,
A simple provable algorithm for curve reconstruction, SODA Proceedings, pp.893-894, 1999. ,
Curve reconstruction: Connecting dots with good reason, SoCG Procedings, vol.15, issue.1, pp.229-244, 1999. ,
Fast reconstruction of curves with sharp corners, Int. J. Comput. Geometry Appl, vol.12, issue.5 1, pp.353-400, 2002. ,
On the shape of a set of points in the plane Robust moving least-squares fitting with sharp features, Proceedings of ACM SIGGRAPH, pp.551-559, 1983. ,
Reconstructing a collection of curves with corners and endpoints, SODA Proceedings, pp.344-353, 2001. ,
Quadric-based simplification in any dimension, ACM Transactions on Graphics, vol.24, issue.8 9, pp.209-239, 2005. ,
Poisson Surface Reconstruction, SGP Proceedings, pp.61-70, 2006. ,
Robust curve reconstruction with k-order alpha-shapes, Shape Modeling International, pp.279-280, 2008. ,
Spectral surface reconstruction from noisy point clouds, SGP Proceedings, pp.11-21, 2004. ,
Conformal wasserstein distances: Comparing surfaces in polynomial time, Advances in Mathematics, issue.2, 2010. ,
Curve reconstruction from unorganized points, Computer Aided Geometric Design, vol.17, issue.2, pp.161-177, 2000. ,
Curve reconstruction in the presence of noise, CGIV Proceedings, pp.177-182, 2007. ,
Abstraction of 2D shapes in terms of parts, NPAR Proceedings, pp.15-24, 2009. ,
Gromov-wasserstein distances and the metric approach to object matching, Foundations of Computational Mathematics, issue.2, 2011. ,
A novel triangulation procedure for thinning hand-written text, Pattern Recognition Letters, vol.22, issue.10 1, pp.1059-1071, 2001. ,
HOT: Hodge Optimized Triangulations, ACM Trans. Graph, issue.2, p.30, 2011. ,
Visibility of noisy point cloud data, Computers and Graphics, vol.34, issue.3 1, pp.219-230, 2010. ,
Computational Geometry: An Introduction, 1985. ,
Ellipsebased principal component analysis for self-intersecting curve reconstruction from noisy point sets, The Visual Computer, vol.27, issue.227 1, 2011. ,
Boundary fitting for 2d curve reconstruction, The Visual Computer, vol.26, pp.187-204, 2010. ,
Topics in Optimal Transportation, 2010. ,
Fast mesh decimation by multiplechoice techniques, Proceedings of the Vision, Modeling, and Visualization Conference, pp.241-248, 2002. ,
