Progressive Compression of Manifold Polygon Meshes - Archive ouverte HAL Access content directly
Journal Articles Computers and Graphics Year : 2012
This paper presents a new algorithm for the progressive compression of manifold polygon meshes. The input surface is decimated by several traversals that generate successive levels of detail through a specific patch decimation operator which combines vertex removal and local remeshing. The mesh connectivity is encoded by two lists of Boolean error predictions based on the mesh geometry: one for the inserted edges and the other for the faces with a removed center vertex. The mesh geometry is encoded with a barycentric error prediction of the removed vertex coordinates and a local curvature prediction. We also include two methods that improve the rate-distortion performance: a wavelet formulation with a lifting scheme and an adaptive quantization technique. Experimental results demonstrate the effectiveness of our approach in terms of compression rates and rate-distortion performance.
Keywords
SMI12.pdf (9.48 Mo) Télécharger le fichier
Format : Figure, Image
Dates and versions
hal-00758024 , version 1 (29-05-2013)
Identifiers
  • HAL Id : hal-00758024 , version 1
Cite
Adrien Maglo, Clement Courbet, Pierre Alliez, Céline Hudelot. Progressive Compression of Manifold Polygon Meshes. Computers and Graphics, 2012, Shape Modeling International (SMI) Conference 2012, 36 (5), pp.349-359. ⟨hal-00758024⟩
351 View
505 Download
Share
