Connectivity compression for irregular quadrilateral meshes ,
Face fixer, Proceedings of the 27th annual conference on Computer graphics and interactive techniques , SIGGRAPH '00, pp.263-270, 2000. ,
DOI : 10.1145/344779.344919
Efficient coding of non-triangular mesh connectivity, Proceedings the Eighth Pacific Conference on Computer Graphics and Applications, p.235, 2000. ,
DOI : 10.1109/PCCGA.2000.883946
Compressing polygon mesh connectivity with degree duality prediction, Graphics Interface Conference Proc, 2002. ,
Near-Optimal Connectivity Encoding of 2-Manifold Polygon Meshes, Graphical Models, vol.64, issue.3-4, pp.147-168, 2002. ,
DOI : 10.1006/gmod.2002.0575
URL : https://hal.archives-ouvertes.fr/inria-00072013
Random Accessible Hierarchical Mesh Compression for Interactive Visualization, Proc. of the Symposium on Geometry Processing, pp.1311-1318, 2009. ,
DOI : 10.1111/j.1467-8659.2009.01508.x
URL : https://hal.archives-ouvertes.fr/hal-00825268
Rate-distortion optimization for progressive compression of 3D mesh with color attributes, The Visual Computer, vol.10, issue.2, pp.137-153, 2012. ,
DOI : 10.1007/s00371-011-0602-y
URL : https://hal.archives-ouvertes.fr/hal-01352935
Progressive meshes, Proceedings of the 23rd annual conference on Computer graphics and interactive techniques , SIGGRAPH '96, pp.99-108, 1996. ,
DOI : 10.1145/237170.237216
Compressed progressive meshes, IEEE Transactions on Visualization and Computer Graphics, vol.6, issue.1, pp.79-93, 2000. ,
DOI : 10.1109/2945.841122
Efficient compression and rendering of multi-resolution meshes, IEEE Visualization, 2002. VIS 2002., pp.347-354, 2002. ,
DOI : 10.1109/VISUAL.2002.1183794
Progressive coding of 3-d graphic models, Proc. of the IEEE, 1998. ,
Progressive compression of arbitrary triangular meshes, Proc. of the IEEE Visualization Conference, 1999. ,
Progressive compression for lossless transmission of triangle meshes, Proceedings of the 28th annual conference on Computer graphics and interactive techniques , SIGGRAPH '01, pp.195-202, 2001. ,
DOI : 10.1145/383259.383281
Triangle mesh compression, Graphics Interface 98 Conference Proc, pp.26-34, 1998. ,
Wavelet-based progressive compression scheme for triangle meshes: wavemesh, IEEE Transactions on Visualization and Computer Graphics, vol.10, issue.2, pp.123-129, 2004. ,
DOI : 10.1109/TVCG.2004.1260764
URL : https://hal.archives-ouvertes.fr/hal-00537014
Progressive lossless compression of arbitrary simplicial complexes, Proc. of SIGGRAPH, pp.372-379, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00167216
Geometry-guided progressive lossless 3d mesh coding with octree (ot) decomposition, Proc. of SIG- GRAPH, pp.609-616, 2005. ,
R-D optimized progressive compression of 3D meshes using prioritized gate selection and curvature prediction, The Visual Computer, vol.10, issue.2, pp.769-779, 2011. ,
DOI : 10.1007/s00371-011-0565-z
Progressive Lossless Mesh Compression Via Incremental Parametric Refinement, Proc. of the Symposium on Geometry Processing, pp.1301-1310, 2009. ,
DOI : 10.1111/j.1467-8659.2009.01507.x
URL : https://hal.archives-ouvertes.fr/hal-00533562
Feature Oriented Progressive Lossless Mesh Coding, Computer Graphics Forum, vol.10, issue.2, pp.2029-2038, 2010. ,
DOI : 10.1111/j.1467-8659.2010.01789.x
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.348.5401
Spectral compression of mesh geometry, Proceedings of the 27th annual conference on Computer graphics and interactive techniques , SIGGRAPH '00, pp.279-286, 2000. ,
DOI : 10.1145/344779.344924
Shape approximation for efficient progressive mesh compression, 2010 IEEE International Conference on Image Processing, 2010. ,
DOI : 10.1109/ICIP.2010.5653218
Progressive geometry compression, Proceedings of the 27th annual conference on Computer graphics and interactive techniques , SIGGRAPH '00, pp.271-278, 2000. ,
DOI : 10.1145/344779.344922
Compression of Normal Meshes, pp.189-206, 2003. ,
DOI : 10.1007/978-3-662-07443-5_12
Antonini, 3d mesh wavelet coding using efficient model-based bit allocation, Proc. of the First International Symposium on 3D Data Processing Visualization and Transmission, pp.391-394, 2002. ,
An efficient bit allocation for compressing normal meshes with an error-driven quantization, Computer Aided Geometric Design, vol.22, issue.5, pp.466-486, 2005. ,
DOI : 10.1016/j.cagd.2005.04.001
URL : https://hal.archives-ouvertes.fr/hal-00264520
A census of planar maps, Journal canadien de math??matiques, vol.15, issue.0, pp.249-271, 1963. ,
DOI : 10.4153/CJM-1963-029-x
Superfaces: polygonal mesh simplification with bounded error, IEEE Computer Graphics and Applications, vol.16, issue.3, pp.64-77, 1996. ,
DOI : 10.1109/38.491187
NEWELL'S METHOD FOR COMPUTING THE PLANE EQUATION OF A POLYGON, pp.231-232, 1992. ,
DOI : 10.1016/B978-0-08-050755-2.50052-X
Adaptive coarse-to-fine quantization for optimizing rate-distortion of progressive mesh compression, Vision, Modeling, and Visualization Workshop, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-01437771
The Lifting Scheme: A Custom-Design Construction of Biorthogonal Wavelets, Applied and Computational Harmonic Analysis, vol.3, issue.2, pp.186-200, 1996. ,
DOI : 10.1006/acha.1996.0015
Optimal bit allocation in compressed 3D models, Computational Geometry, vol.14, issue.1-3, pp.91-118, 1999. ,
DOI : 10.1016/S0925-7721(99)00025-5
Metro: Measuring Error on Simplified Surfaces, Computer Graphics Forum, vol.17, issue.2, pp.167-174, 1998. ,
DOI : 10.1111/1467-8659.00236
Compressing polygon mesh geometry with parallelogram prediction, IEEE Visualization, 2002. VIS 2002., pp.141-146, 2002. ,
DOI : 10.1109/VISUAL.2002.1183768
Variational shape approximation, Proc. of SIGGRAPH, pp.905-914, 2004. ,
DOI : 10.1145/1186562.1015817
URL : https://hal.archives-ouvertes.fr/inria-00070632
