Abstract Clocks for the DSE of Data-Intensive Applications on MPSoCs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents an approach advocating abstract clocks to represent data-intensive applications executed on multiprocessor systems-on-chip (MPSoCs) for facilitating the exploration of large design spaces. By using abstract clocks, the advocated method characterizes applications defined by multiple loop nests, as well as, useful loop transformations that contribute to an efficient application execution. It combines the advantages of optimizations provided by loop transformations and the precision of information on scheduling captured by the abstract clocks. As a result, it favors a rapid, and yet accurate design space exploration (DSE) of data-intensive systems.
Fichier non déposé
hal-00758165 , version 1 (28-11-2012)
  • HAL Id : hal-00758165 , version 1
Rosilde Corvino, Abdoulaye Gamatié. Abstract Clocks for the DSE of Data-Intensive Applications on MPSoCs. 10th IEEE International Symposium on Parallel and Distributed Processing with Applications (ISPA), Jul 2012, Leganés, Madrid, Spain. pp.729 -736. ⟨hal-00758165⟩
84 Consultations
0 Téléchargements
