Parallel predator-prey interaction for evolutionary multi-objective optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Natural Computing Année : 2012
Over the last decade, the predator-prey model (PPM) has emerged as an alternative algorithmic approach to multi-objective evolutionary optimization, featuring a very simple abstraction from natural species interplay and extensive parallelization potential. While substantial research has been done on the former, we for the first time review the PPM in the light of parallelization: We analyze the architecture and classify its components with respect to a recent taxonomy for parallel multi-objective evolutionary algorithms. Further, we theoretically examine benefits of simultaneous predator collaboration on a spatial population structure and give insights into solution emergence. On the prey level, we integrate a gradient-based local search mechanism to exploit problem independent parallelization and hybridize the model in order to achieve faster convergence and solution stability. This way, we achieve a good approximation and unfold further parallelization potential for the model.
nc_glp2010_online.pdf (1.19 Mo) Télécharger le fichier
hal-00758211 , version 1 (28-11-2012)
Grimme Christian, Joachim Lepping, Papaspyrou Alexander. Parallel predator-prey interaction for evolutionary multi-objective optimization. Natural Computing, 2012, 11 (3), pp.519-533. ⟨10.1007/s11047-011-9266-9⟩. ⟨hal-00758211⟩
143 Consultations
278 Téléchargements
