M. Abadie, Dynamic Simulation of Rigid Bodies: Modelling of Frictional Contact, Impacts in Mechanical Systems: Analysis and Modelling, pp.61-144, 2000.
DOI : 10.1007/3-540-45501-9_2
V. Acary, Toward higher order event-capturing schemes and adaptive timestep strategies for nonsmooth multibody systems, 2009.
DOI : 10.1016/j.apnum.2012.06.026
URL : https://hal.archives-ouvertes.fr/inria-00440771
V. Acary, Higher order event capturing time-stepping schemes for nonsmooth multibody systems with unilateral constraints and impacts, Applied Numerical Mathematics, vol.62, issue.10, pp.1259-1275, 2012.
URL : https://hal.archives-ouvertes.fr/inria-00476398
V. Acary and B. Brogliato, Numerical Methods for Nonsmooth Dynamical Systems: Applications in Mechanics and Electronics, Lecture Notes in Applied and Computational Mechanics, vol.35, 2008.
URL : https://hal.archives-ouvertes.fr/inria-00423530
V. Acary, F. Cadoux, C. Lemaréchal, and J. Malick, A formulation of the linear discrete Coulomb friction problem via convex optimization, ZAMM - Journal of Applied Mathematics and Mechanics / Zeitschrift f??r Angewandte Mathematik und Mechanik, vol.5, issue.4, pp.155-175, 2011.
DOI : 10.1002/(SICI)1099-1484(200005)5:4<305::AID-CFM96>3.0.CO;2-W
URL : https://hal.archives-ouvertes.fr/inria-00495734
V. Acary and F. Pérignon, An introduction to Siconos, 2007.
URL : https://hal.archives-ouvertes.fr/inria-00162911
P. Ballard, The Dynamics of Discrete Mechanical Systems with Perfect Unilateral Constraints, Archive for Rational Mechanics and Analysis, vol.154, issue.3, pp.199-274, 2000.
DOI : 10.1007/s002050000105
URL : https://hal.archives-ouvertes.fr/hal-00111308
P. Ballard, Bounded variations and measure theory on the line, Lectures notes of the second summer on Nonsmooth Dynamics, Autrans, 2003.
O. A. Bauchau and A. Laulusa, Review of Contemporary Approaches for Constraint Enforcement in Multibody Systems, Journal of Computational and Nonlinear Dynamics, vol.3, issue.1, p.11005, 2008.
DOI : 10.1115/1.2803258
B. Brogliato, Nonsmooth Mechanics: Models, Dynamics and Control, 1999.
DOI : 10.1007/978-3-319-28664-8
URL : https://hal.archives-ouvertes.fr/hal-01236953
N. J. Carpenter, R. L. Taylor, and M. G. Katona, Lagrange constraints for transient finite element surface contact, International Journal for Numerical Methods in Engineering, vol.1, issue.1, pp.103-128, 1991.
DOI : 10.1002/nme.1620320107
URL : https://hal.archives-ouvertes.fr/hal-01389918
Q. Z. Chen, V. Acary, G. Virlez, and O. Brüls, A newmark-type integrator for flexible systems considering nonsmooth unilateral constraints, The Second Joint International Conference on Multibody System Dynamics ? IMSD 2012, 2012.
URL : https://hal.archives-ouvertes.fr/hal-00681252
G. De-saxcé and Z. Feng, New Inequality and Functional for Contact with Friction: The Implicit Standard Material Approach???, Mechanics of Structures and Machines, vol.273, issue.3, pp.301-325, 1991.
DOI : 10.1016/0045-7949(80)90146-7
P. Deuflhard, R. Krause, and S. , A contact-stabilized Newmark method for dynamical contact problems, International Journal for Numerical Methods in Engineering, vol.1, issue.9, pp.1274-1290, 2007.
DOI : 10.1007/978-1-4612-5152-1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.561.8320
D. Doyen, A. Ern, and S. Piperno, Time-Integration Schemes for the Finite Element Dynamic Signorini Problem, SIAM Journal on Scientific Computing, vol.33, issue.1, pp.223-249, 2011.
DOI : 10.1137/100791440
URL : https://hal.archives-ouvertes.fr/hal-00440128
R. Dzonou, M. D. Monteiro-marques, and L. Paoli, A convergence result for a vibroimpact problem with a general inertia operator, Nonlinear Dyn, pp.1-2, 2009.
R. Flores, P. Leine, and C. Glocker, Modeling and analysis of planar rigid multibody systems with translational clearance joints based on the non-smooth dynamics approach, Multibody System Dynamics, vol.76, issue.11, pp.165-190, 2010.
DOI : 10.1007/978-3-7091-2624-0_1
URL : https://hal.archives-ouvertes.fr/hal-01435625
C. W. Gear, B. Leimkuhler, and G. K. Gupta, Automatic integration of Euler-Lagrange equations with constraints, Journal of Computational and Applied Mathematics, vol.12, issue.13, pp.12-13, 1985.
DOI : 10.1016/0377-0427(85)90008-1
F. Génot and B. Brogliato, New results on Painlev?? paradoxes, European Journal of Mechanics - A/Solids, vol.18, issue.4, pp.653-677, 1999.
DOI : 10.1016/S0997-7538(99)00144-8
M. Géradin and A. Cardona, Flexible Multibody Dynamics: A finite element Approach, 2001.
E. Hairer, . Ch, G. Lubich, and . Wanner, Geometric Numerical Integration. Structure- Preserving Algorithms for Ordinary Differential Equations, 2006.
DOI : 10.1007/978-3-662-05018-7
URL : https://hal.archives-ouvertes.fr/hal-01403326
T. J. Hughes, The Finite Element Method, Linear Static and Dynamic Finite Element Analysis, 1987.
T. J. Hughes, R. L. Taylor, J. L. Sackman, A. Curnier, and W. Kanoknukulcahi, A finite element method for a class of contact-impact problems, Computer Methods in Applied Mechanics and Engineering, vol.8, issue.3, pp.249-276, 1976.
DOI : 10.1016/0045-7825(76)90018-9
O. Janin and C. H. Lamarque, Comparison of several numerical methods for mechanical systems with impacts, International Journal for Numerical Methods in Engineering, vol.51, issue.9, pp.1101-1132, 2001.
DOI : 10.1002/nme.206
URL : https://hal.archives-ouvertes.fr/hal-00814950
M. Jean, The non-smooth contact dynamics method, Computational Modeling of Contact and Friction, pp.235-257, 1999.
DOI : 10.1016/S0045-7825(98)00383-1
URL : https://hal.archives-ouvertes.fr/hal-01390459
M. Jean and J. J. Moreau, Unilaterality and dry friction in the dynamics of rigid bodies collections, Proc. of Contact Mech Presses Polytechniques et Universitaires Romandes, pp.31-48, 1992.
F. Jourdan, P. Alart, and M. Jean, A Gauss-Seidel like algorithm to solve frictional contact problems, Computer Methods in Applied Mechanics and Engineering, vol.155, issue.1-2, pp.31-47, 1998.
DOI : 10.1016/S0045-7825(97)00137-0
H. B. Khenous, P. Laborde, and Y. Renard, On the discretization of contact problems in elastodynamics, Papers Based on the Presentation at the Fourth Contact Mechanics International Symposium (CMIS 2005), pp.31-38, 2005.
DOI : 10.1007/3-540-31761-9_4
H. B. Khenous, P. Laborde, and Y. Renard, Mass redistribution method for finite element contact problems in elastodynamics, European Journal of Mechanics - A/Solids, vol.27, issue.5, pp.918-932, 2008.
DOI : 10.1016/j.euromechsol.2008.01.001
URL : https://hal.archives-ouvertes.fr/hal-00381443
T. A. Laursen and V. Chawla, DESIGN OF ENERGY CONSERVING ALGORITHMS FOR FRICTIONLESS DYNAMIC CONTACT PROBLEMS, International Journal for Numerical Methods in Engineering, vol.37, issue.5, pp.863-886, 1997.
DOI : 10.1016/0045-7949(90)90324-U
URL : https://hal.archives-ouvertes.fr/hal-01435617
T. A. Laursen and G. R. Love, Improved implicit integrators for transient impact problems?geometric admissibility within the conserving framework, International Journal for Numerical Methods in Engineering, vol.32, issue.2, pp.245-274, 2002.
T. A. Laursen and G. R. Love, Improved implicit integrators for transient impact problems ? Dynamical frcitional dissipation within an admissible conserving framework, Comput. Methods Appl. Mech. Engrg, vol.192, pp.2223-2248, 2003.
J. J. Moreau, Unilateral Contact and Dry Friction in Finite Freedom Dynamics, Nonsmooth Mechanics and Applications, CISM, Courses and Lectures, pp.1-82, 1988.
J. J. Moreau, Numerical aspects of the sweeping process, Computational Modeling of Contact and Friction, pp.329-349, 1999.
DOI : 10.1016/S0045-7825(98)00387-9
URL : https://hal.archives-ouvertes.fr/hal-01349847
J. M. Ortega and W. C. Rheinboldt, Iterative Solution of Nonlinear Equations in Several Variables, Classics in Applied Mathematics, SIAM, 2000.
DOI : 10.1137/1.9780898719468
L. Paoli, An existence result for non-smooth vibro-impact problems, Journal of Differential Equations, vol.211, issue.2, pp.247-281, 2005.
DOI : 10.1016/j.jde.2004.11.008
URL : https://hal.archives-ouvertes.fr/hal-01569156
L. Paoli and M. Schatzman, A Numerical Scheme for Impact Problems I: The One-Dimensional Case, SIAM Journal on Numerical Analysis, vol.40, issue.2, pp.702-733, 2002.
DOI : 10.1137/S0036142900378728
]. L. Paoli and M. Schatzman, A Numerical Scheme for Impact Problems II: The Multidimensional Case, SIAM Journal on Numerical Analysis, vol.40, issue.2, pp.734-768, 2002.
DOI : 10.1137/S003614290037873X
K. C. Park, S. J. Lim, and H. Huh, A method for computation of discontinuous wave propagation in heterogeneous solids: basic algorithm description and application to one-dimensional problems, International Journal for Numerical Methods in Engineering, vol.47, issue.2, pp.622-643, 2012.
DOI : 10.1002/(SICI)1097-0207(20000110/30)47:1/3<395::AID-NME777>3.0.CO;2-9
URL : https://hal.archives-ouvertes.fr/hal-01443190
F. Pfeiffer and C. Glocker, Multibody Dynamics with Unilateral Contacts Non-linear Dynamics, 1996.
3. Pythonocc, . Cad, and . Cae, PLM development framework for the Python programming language
R. T. Rockafellar, Convex Analysis, 1970.
DOI : 10.1515/9781400873173
M. Schatzman, A class of nonlinear differential equations of second order in time, Nonlinear Anal, pp.355-373, 1978.
M. Schatzman, A hyperbolic problem of second order with unilateral constraints: The vibrating string with a concave obstacle, Journal of Mathematical Analysis and Applications, vol.73, issue.1, pp.138-191, 1980.
DOI : 10.1016/0022-247X(80)90026-8
M. Schatzman, Un probl??me hyperbolique du 2??me ordre avec contrainte unilat??rale: La corde vibrante avec obstacle ponctuel, Journal of Differential Equations, vol.36, issue.2, pp.295-334, 1980.
DOI : 10.1016/0022-0396(80)90068-6
URL : http://doi.org/10.1016/0022-0396(80)90068-6
M. Schatzman and M. Bercovier, Numerical approximation of a wave equation with unilateral constraints, Mathematics of Computation, vol.53, issue.187, pp.55-79, 1989.
DOI : 10.1090/S0025-5718-1989-0969491-5
URL : https://hal.archives-ouvertes.fr/hal-01295436
T. Schindler and V. Acary, Timestepping schemes for nonsmooth dynamics based on discontinuous Galerkin methods: Definition and outlook, Mathematics and Computers in Simulation, vol.95
DOI : 10.1016/j.matcom.2012.04.012
URL : https://hal.archives-ouvertes.fr/inria-00595460
. Siconos, A software for modeling and simulation of nonsmooth dynamical systems
D. Stewart, Convergence of a Time-Stepping Scheme for Rigid-Body Dynamics and Resolution of Painlev??'s Problem, Archive for Rational Mechanics and Analysis, vol.145, issue.3, pp.215-260, 1998.
DOI : 10.1007/s002050050129
D. Stewart, Rigid-Body Dynamics with Friction and Impact, SIAM Review, vol.42, issue.1, pp.3-39, 2000.
DOI : 10.1137/S0036144599360110
URL : https://hal.archives-ouvertes.fr/hal-01570533
C. Studer, Numerics of Unilateral Contacts and Friction. Modeling and Numerical Time Integration in Non-Smooth Dynamics, Lecture Notes in Applied and Computational Mechanics, 2009.
C. Studer, R. I. Leine, . Ch, and . Glocker, Step size adjustment and extrapolation for time-stepping schemes in non-smooth dynamics, International Journal for Numerical Methods in Engineering, vol.55, issue.2, pp.1747-1781, 2008.
DOI : 10.1007/978-3-663-01227-6
URL : https://hal.archives-ouvertes.fr/hal-01352897
T. A. Laursen, Computational Contact and Impact Mechanics ? Fundamentals of Modeling Interfacial Phenomena in Nonlinear Finite Element Analysis, 2003.
P. Wriggers, Computational Contact Mechanics, 2002.
URL : https://hal.archives-ouvertes.fr/hal-00466790
