HyDi: A Hybrid Data Dissemination Protocol for Highway Scenarios in Vehicular Ad hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we tackle the problem of data dissemination under both well-connected and intermittently connected ve- hicular ad hoc networks. For such a purpose, we propose HyDi, a data dissemination protocol suited for highway sce- narios. HyDi can seamless operate under both well-connected networks by applying broadcast suppression techniques in order to avoid contention at the link layer, and also at intermittently connected networks by applying store-carry-forward techniques, thus delivering messages even when an end-to-end path is non-existent. By means of simulation using the recently de ned IEEE 802.11p standard, we compare HyDi against the only two existing solutions in the literature - DV-CAST and SRD - and we show that HyDi has an overhead as good as DV-CAST, outperforms both protocols when considering the average delay under heavy tra cscenarios, decreases the average number of hops to deliver messages and can deliver data to almost all nodes in a given region of interest.
Fichier non déposé
hal-00758907 , version 1 (29-11-2012)
  • HAL Id : hal-00758907 , version 1
Guilherme Maia, Daniel L. Guidoni, Aline Carneiro Viana, André L. L. Aquino, Raquel A. F. Mini, et al.. HyDi: A Hybrid Data Dissemination Protocol for Highway Scenarios in Vehicular Ad hoc Networks. 2nd ACM Symposium on Development and Analysis of Intelligent Vehicular Networks and Applications (ACM DIVANet) in conjunction with ACM MSWIM 2012, Oct 2012, Paphos, Cyprus. ⟨hal-00758907⟩
184 Consultations
0 Téléchargements
