High order preserving residual distribution schemes for advection-diffusion scalar problems on arbitrary grids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
This paper deals with the construction of a class of high order accurate Residual Distribution schemes for advection-diffusion problems using conformal meshes. The problems we consider range from pure difusion to pure advection. The approximation of the solution is obtained using standard Lagrangian finite elements and the total residual of the problem is constructed taking into account both the advective and the diffusive terms in order to discretize with the same scheme both parts of the governing equation. To cope with the fact that the normal component of the gradients of the numerical solution is discontinuous across the faces of the elements, the gradient of the numerical solution is recovered at each degree of freedom of the grid and then interpolated with the same shape functions used for the solution. Linear and non-linear schemes are constructed and their accuracy is tested with the discretization of advection-diffusion and anisotropic diffusion problems.This paper deals with the construction of a class of high order accurate Residual Distribution schemes for advection-diffusion problems using conformal meshes. The problems we consider range from pure difusion to pure advection. The approximation of the solution is obtained using standard Lagrangian finite elements and the total residual of the problem is constructed taking into account both the advective and the diffusive terms in order to discretize with the same scheme both parts of the governing equation. To cope with the fact that the normal component of the gradients of the numerical solution is discontinuous across the faces of the elements, the gradient of the numerical solution is recovered at each degree of freedom of the grid and then interpolated with the same shape functions used for the solution. Linear and non-linear schemes are constructed and their accuracy is tested with the discretization of advection-diffusion and anisotropic diffusion problems.
RR_NS.pdf (2.2 Mo) Télécharger le fichier
hal-00758930 , version 1 (29-11-2012)
hal-00758930 , version 2 (05-12-2012)
  • HAL Id : hal-00758930 , version 1
Remi Abgrall, Dante de Santis, Mario Ricchiuto. High order preserving residual distribution schemes for advection-diffusion scalar problems on arbitrary grids. [Research Report] RR-8157, 2012, pp.43. ⟨hal-00758930v1⟩
275 Consultations
401 Téléchargements
