A hybrid multi-view stereo algorithm for modeling urban scenes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Pattern Analysis and Machine Intelligence Année : 2013
We present an original multi-view stereo reconstruction algorithm which allows the 3D-modeling of urban scenes as a combination of meshes and geometric primitives. The method provides a compact model while preserving details: irregular elements such as statues and ornaments are described by meshes whereas regular structures such as columns and walls are described by primitives (planes, spheres, cylinders, cones and tori). We adopt a two-step strategy consisting first in segmenting the initial meshbased surface using a multi-label Markov Random Field based model and second, in sampling primitive and mesh components simultaneously on the obtained partition by a Jump-Diffusion process. The quality of a reconstruction is measured by a multi-object energy model which takes into account both photo-consistency and semantic considerations (i.e. geometry and shape layout). The segmentation and sampling steps are embedded into an iterative refinement procedure which provides an increasingly accurate hybrid representation. Experimental results on complex urban structures and large scenes are presented and compared to the state-of-the-art multi-view stereo meshing algorithms.
pami_2012.pdf (2.18 Mo) Télécharger le fichier
Format : Figure, Image
hal-00759261 , version 1 (30-11-2012)
Florent Lafarge, Renaud Keriven, Mathieu Brédif, Hoang-Hiep Vu. A hybrid multi-view stereo algorithm for modeling urban scenes. IEEE Transactions on Pattern Analysis and Machine Intelligence, 2013, 35 (1), pp.5-17. ⟨10.1109/TPAMI.2012.84⟩. ⟨hal-00759261⟩
764 Consultations
3948 Téléchargements
