Controllability of a nonlinear hybrid system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annals of the University of Craiova. Mathematics and Computer Science series Année : 2011
In this paper we study a controllability problem for a simplified 1-d nonlinear system which models the self-propelled motion of a rigid body in a fluid located on the real axis. The control variable is the difference of the velocities of the fluid and the solid and depends only on time. The main result of the paper asserts that any final position and velocity of the rigid body can be reached by a suitable input function.
Fichier non déposé
hal-00759342 , version 1 (30-11-2012)
  • HAL Id : hal-00759342 , version 1
Nicolae Cindea, Sorin Micu, Ionel Roventa, Marius Tucsnak. Controllability of a nonlinear hybrid system. Annals of the University of Craiova. Mathematics and Computer Science series, 2011, 38 (1), pp.35-48. ⟨hal-00759342⟩
143 Consultations
0 Téléchargements
