Parallel computation of entries of A-1 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
In this paper, we are concerned about computing in parallel several entries of the inverse of a large sparse matrix. We assume that the matrix has already been factorized by a direct method and that the factors are distributed. Entries are efficiently computed by exploiting sparsity of the right-hand sides and the solution vectors in the triangular solution phase. We demonstrate that in this setting, parallelism and computational efficiency are two contrasting objectives. We develop an efficient approach and show its efficacy by runs using the MUMPS code that implements a parallel multifrontal method.
RR-8142.pdf (585.22 Ko) Télécharger le fichier
hal-00759556 , version 1 (01-12-2012)
hal-00759556 , version 2 (21-12-2012)
  • HAL Id : hal-00759556 , version 2
Patrick Amestoy, Iain S. Duff, Jean-Yves L'Excellent, François-Henry Rouet. Parallel computation of entries of A-1. [Research Report] RR-8142, INRIA. 2012. ⟨hal-00759556v2⟩
239 Consultations
573 Téléchargements
