A Fully Asynchronous Multifrontal Solver Using Distributed Dynamic Scheduling, SIAM Journal on Matrix Analysis and Applications, vol.23, issue.1, pp.15-41, 2001. ,
DOI : 10.1137/S0895479899358194
URL : https://hal.archives-ouvertes.fr/hal-00808293
On Computing Inverse Entries of a Sparse Matrix in an Out-of-Core Environment, SIAM Journal on Scientific Computing, vol.34, issue.4, pp.1975-1999, 2012. ,
DOI : 10.1137/100799411
URL : https://hal.archives-ouvertes.fr/hal-00763556
Hybrid scheduling for the parallel solution of linear systems, Parallel Computing, vol.32, issue.2, pp.136-156, 2006. ,
DOI : 10.1016/j.parco.2005.07.004
URL : https://hal.archives-ouvertes.fr/hal-00358623
Numerical methods for least squares problems, Society for Industrial Mathematics, 1996. ,
DOI : 10.1137/1.9781611971484
INTEGRAL SPI Observation of the Galactic Central Radian: Contribution of Discrete Sources and Implication for the Diffuse Emission 1, The Astrophysical Journal, pp.635-1103, 2005. ,
Computing the sparse inverse subset: an inverse multifrontal approach, 1995. ,
A parallel implementation of the block-partitioned inverse multifrontal Zsparse algorithm, 1995. ,
A scalable distributed method for quantum-scale device simulation, Journal of Applied Physics, vol.101, issue.12, p.123715, 2007. ,
DOI : 10.1063/1.2748621
Task scheduling for parallel sparse Cholesky factorization, International Journal of Parallel Programming, vol.27, issue.4, pp.291-314, 1989. ,
DOI : 10.1007/BF01407861
Fast algorithm for extracting the diagonal of the inverse matrix with application to the electronic structure analysis of metallic systems, Communications in Mathematical Sciences, 2009. ,
A Fast Parallel Algorithm for Selected Inversion of Structured Sparse Matrices with Application to 2D Electronic Structure Calculations, SIAM Journal on Scientific Computing, vol.33, issue.3, pp.1329-1351, 2011. ,
DOI : 10.1137/09077432X
Atomistic simulation of nanowires in the sp 3 d 5 s * tight-binding formalism: From boundary conditions to strain calculations, Physical Review B, pp.74-205323, 2006. ,
Efficient Methods for Large Resistor Networks, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.29, issue.1, pp.28-39, 2010. ,
DOI : 10.1109/TCAD.2009.2034402
Memory and performance issues in parallel multifrontal factorizations and triangular solutions with sparse right-hand sides, 2012. ,
URL : https://hal.archives-ouvertes.fr/tel-00785748
Parallel triangular solution in the out-of-core multifrontal approach for solving large sparse linear systems, 2009. ,
Formation of a sparse bus impedance matrix and its application to short circuit study, Proceedings 8th PICA Conference, 1973. ,
