Optimal stability for inverse elliptic boundary value problems with unknown boundaries, Ann. Scuola Norm. Sup. Pisa Cl. Sci, vol.29, issue.44, pp.755-806, 2000. ,
Stable determination of corrosion by a single electrostatic boundary measurement, Sobolev spaces, pp.973-984, 2003. ,
DOI : 10.1088/0266-5611/19/4/312
Detecting nonlinear corrosion by electrostatic measurements, Applicable Analysis, vol.46, issue.1-3, pp.107-128, 2006. ,
DOI : 10.1112/blms/26.4.353
URL : http://arxiv.org/abs/math/0406575
Stability estimate for an inverse boundary coefficient problem in thermal imaging, Journal of Mathematical Analysis and Applications, vol.343, issue.1, pp.328-336, 2008. ,
DOI : 10.1016/j.jmaa.2008.01.066
Stability of the determination of the surface impedance of an obstacle from the scattering???amplitude, Mathematical Methods in the Applied Sciences, vol.12, issue.11, p.2012 ,
DOI : 10.1002/mma.2762
URL : https://hal.archives-ouvertes.fr/hal-00659032
About stability and regularization of ill-posed elliptic Cauchy problems: the case of Lipschitz domains, Egloffe, and C. Grandmont. Stability estimates for a robin coefficient in the two-dimensional stokes system. Accepted for publication in Mathematical control and related field, pp.1745-1768, 2010. ,
DOI : 10.1002/nme.1620080408
URL : https://hal.archives-ouvertes.fr/hal-00849579
´ Eléments d'analyse pour l'´ etude de quelques modèles d'´ ecoulements de fluides visqueux incompressibles, ) [Mathematics & Applications, 2006. ,
DOI : 10.1007/3-540-29819-3
MULTISCALE MODELING OF THE RESPIRATORY TRACT, Mathematical Models and Methods in Applied Sciences, vol.20, issue.01, pp.59-93, 2010. ,
DOI : 10.1142/S0218202510004155
Interpolation spaces. An introduction, 1976. ,
About stability and regularization of ill-posed elliptic Cauchy problems: the case of C 1,1 domains Stable determination of a boundary coefficient in an elliptic equation, M2AN Math. Model. Numer. Anal. Math. Models Methods Appl. Sci, vol.44, issue.181, pp.715-735107, 2008. ,
Logarithmic stability estimates for a Robin coefficient in two-dimensional Laplace inverse problems, Inverse Problems, vol.20, issue.1, pp.47-59, 2004. ,
DOI : 10.1088/0266-5611/20/1/003
Identification of Robin coefficients by the means of boundary measurements, Inverse Problems, vol.15, issue.6, pp.1425-1438, 1999. ,
DOI : 10.1088/0266-5611/15/6/303
Carleman estimates for the Zaremba Boundary Condition and Stabilization of Waves, American Journal of Mathematics, vol.136, issue.2, 2011. ,
DOI : 10.1353/ajm.2014.0014
URL : https://hal.archives-ouvertes.fr/hal-00634867
Mathematical analysis and numerical methods for science and technology Physical origins and classical methods, With the collaboration of Philippe Bénilan, 1990. ,
Etude de quelquesprobì emes inverses pour le système de Stokes Application aux poumons, Imanuvilov. Controllability of evolution equations Lecture Notes Series, vol.34, 1996. ,
Prolongement unique des solutions de l'equation de Stokes, Comm. Partial Differential Equations, vol.21, pp.3-4573, 1996. ,
DOI : 10.1080/03605309608821198
Caccioppoli's inequality and Legendre-Hadamard condition, Mathematische Annalen, vol.17, issue.312, pp.105-107, 1985. ,
DOI : 10.1007/BF01455535
The analysis of linear partial differential operators. III, of Grundlehren der Mathematischen Wissenschaften [Fundamental Principles of Mathematical Sciences, 1985. ,
Méthode de quasi-réversibilité et applications, Travaux et Recherches Mathématiques, issue.15, 1967. ,
Contr??le Exact De L??quation De La Chaleur, Communications in Partial Differential Equations, vol.52, issue.1-2, pp.335-356, 1995. ,
DOI : 10.1016/0022-0396(87)90043-X
Interpolation theory. Appunti. Scuola Normale Superiore di Pisa (Nuova Serie). [Lecture Notes, Scuola Normale Superiore di Pisa (New Series)]. Edizioni della Normale, 2009. ,
Optimal three-ball inequalities and quantitative uniqueness for the Stokes system, Discrete and Continuous Dynamical Systems, vol.28, issue.3, pp.1273-1290, 2010. ,
DOI : 10.3934/dcds.2010.28.1273
Remarques sur l'observabilité pour l'´ equation de laplace. ESAIM: Control, Optimisation and Calculus of Variations, pp.621-635, 2003. ,
DOI : 10.1051/cocv:2003030
URL : http://archive.numdam.org/article/COCV_2003__9__621_0.pdf
Analysis of a Geometrical Multiscale Model Based on the Coupling of ODE and PDE for Blood Flow Simulations, Multiscale Modeling & Simulation, vol.1, issue.2, pp.173-195, 2003. ,
DOI : 10.1137/S1540345902408482
Théorème d'unicité adapté au contrôle des solutions desprobì emes hyperboliques, Comm. Partial Differential Equations, vol.16, issue.4-5, pp.789-800, 1991. ,
Lipschitz stability for the inverse Robin problem, Inverse Problems, vol.23, issue.3, pp.1311-1326, 2007. ,
Outflow boundary conditions for three-dimensional finite element modeling of blood flow and pressure in arteries, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.29-32, pp.29-323776, 2006. ,
DOI : 10.1016/j.cma.2005.04.014
