Tracking Control and Robustness Analysis for PVTOL Aircraft under Bounded Feedbacks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2012
We study feedback tracking problems for the planar vertical takeoff and landing (PVTOL) aircraft dynamics, which is a benchmark model in aerospace engineering. We provide a survey of the literature on the model. Then we construct new feedback stabilizers for the PVTOL tracking dynamics. The novelty of our work is in the boundedness of our feedback controllers and their applicability to cases where the velocity measurements may not be available, coupled with the uniform global asymptotic stability and uniform local exponential stability of the closed loop tracking dynamics, and the input-to-state stable performance of the closed loop tracking dynamics with respect to actuator errors. Our proofs are based on a new bounded backstepping result that is of independent interest. We illustrate our work in a tracking problem along a circle.
Automatique
Fichier non déposé
hal-00760082 , version 1 (03-12-2012)
  • HAL Id : hal-00760082 , version 1
Aleksandra Gruszka, Michael Malisoff, Frédéric Mazenc. Tracking Control and Robustness Analysis for PVTOL Aircraft under Bounded Feedbacks. International Journal of Robust and Nonlinear Control, 2012, 22 (17), pp.1899-1920. ⟨hal-00760082⟩
151 Consultations
0 Téléchargements
