Principles of constraint programming, 2003. ,
Differential Privacy for Relational Algebra: improving the sensitivity bound via constraints systems, 2012. ,
A relational model of data for large shared data banks, Communications of the ACM, vol.13, issue.6, pp.377-387, 1970. ,
DOI : 10.1145/362384.362685
Relational Completeness of Database Sublanguages, Base Systems, 1972. ,
Differential Privacy, Proc. of ICALP, pp.1-12, 2006. ,
DOI : 10.1007/11787006_1
Differential Privacy: A Survey of Results, pp.1-19, 2008. ,
DOI : 10.1007/978-3-540-79228-4_1
A firm foundation for private data analysis, Communications of the ACM, vol.54, issue.1, pp.86-96, 2011. ,
DOI : 10.1145/1866739.1866758
Differential privacy and robust statistics, Proceedings of the 41st annual ACM symposium on Symposium on theory of computing, STOC '09, pp.371-380, 2009. ,
DOI : 10.1145/1536414.1536466
Calibrating Noise to Sensitivity in Private Data Analysis Privacy integrated queries: an extensible platform for privacy-preserving data analysis, SIGMOD Conference, pp.265-284, 2006. ,
Distance makes the types grow stronger: a calculus for differential privacy, pp.157-168, 2010. ,
