Numerical framework for patient-specific computational modelling of vascular tissue, International Journal for Numerical Methods in Biomedical Engineering, vol.76, issue.1, pp.35-51, 2010. ,
DOI : 10.1002/cnm.1234
A nudging-based data assimilation method: the Back and Forth Nudging (BFN) algorithm, Nonlinear Processes in Geophysics, vol.15, issue.2, pp.305-319, 2008. ,
DOI : 10.5194/npg-15-305-2008
URL : https://hal.archives-ouvertes.fr/inria-00327422
Signed Distance Computation Using the Angle Weighted Pseudonormal, IEEE Transactions on Visualization and Computer Graphics, vol.11, issue.3, pp.243-253, 2005. ,
DOI : 10.1109/TVCG.2005.49
State observers of a vascular fluid-structure interaction model through measurements in the solid Sequential parameter estimation for fluid-structure problems. application to hemodynamics, Int J Num Meth Biomedical Engng, vol.28, issue.4, pp.434-455, 1957. ,
Data Assimilation for Geophysical Fluids, Computational Methods for the Atmosphere and the Oceans, vol.14, pp.385-441, 2009. ,
DOI : 10.1016/S1570-8659(08)00209-3
URL : https://hal.archives-ouvertes.fr/inria-00391892
Importance of realistic LVAD profiles for assisted aortic simulations: evaluation of optimal outflow anastomosis lo- cations Buerger C, Schaeffter T, King A (2011) Hierarchical adaptive local affine registration for fast and robust respiratory motion estimation, Medical Image Analysis, vol.15, issue.4, pp.551-564, 2011. ,
Geodesic active contours, Proceedings of IEEE International Conference on Computer Vision, pp.61-79, 1997. ,
DOI : 10.1109/ICCV.1995.466871
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.21.2196
Efficient pipeline for image-based patient-specific analysis of cerebral aneurysm hemodynamics: technique and sensitivity, IEEE Transactions on Medical Imaging, vol.24, issue.4, pp.457-467, 2005. ,
DOI : 10.1109/TMI.2005.844159
Estimation of tissue contractility from cardiac cine-MRI using a biomechanical heart model, Biomechanics and Modeling in Mechanobiology, vol.3, issue.4, pp.609-630, 2011. ,
DOI : 10.1007/s10237-011-0337-8
URL : https://hal.archives-ouvertes.fr/hal-00654541
Improving convergence in numerical analysis using observers. the wave-like equation case. M3AS In press Chavent G (2010) Nonlinear Least Squares for Inverse Problems A projection semi-implicit scheme for the coupling of an elastic structure with an incompressible fluid, Theoretical Foundations and Step-by- Step Guide for Applications, pp.794-821, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00621052
Fluid structure interaction problems in haemodynamics A coupled momentum method for modeling blood flow in three-dimensional deformable arteries, Mathematical Modelling of the Cardiovascular System, pp.41-435685, 2006. ,
On the coupling of 3D and 1D Navier???Stokes equations for flow problems in compliant vessels, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.6-7, pp.6-7561, 2001. ,
DOI : 10.1016/S0045-7825(01)00302-4
URL : https://hal.archives-ouvertes.fr/hal-00691928
A computational strategy for prestressing patient-specific biomechanical problems under finite deformation, International Journal for Numerical Methods in Biomedical Engineering, vol.74, issue.1, pp.52-72, 2010. ,
DOI : 10.1186/1475-925X-6-38
Fluid???structure interaction in blood flows on geometries based on medical imaging, Computers & Structures, vol.83, issue.2-3, pp.155-165, 2005. ,
DOI : 10.1016/j.compstruc.2004.03.083
Reduced sigma point filters for the propagation of means and covariances through nonlinear transformations, Proceedings of the 2002 American Control Conference (IEEE Cat. No.CH37301), pp.887-892, 2002. ,
DOI : 10.1109/ACC.2002.1023128
Linear estimation, 2000. ,
Coupling of a 3D Finite Element Model of Cardiac Ventricular Mechanics to Lumped Systems Models of the Systemic and Pulmonic Circulation, Annals of Biomedical Engineering, vol.47, issue.1, pp.1-18, 2007. ,
DOI : 10.1007/s10439-006-9212-7
An introduction to observers, IEEE Transactions on Automatic Control, vol.16, issue.6, pp.596-602, 1971. ,
DOI : 10.1109/TAC.1971.1099826
Parameter identification for a one-dimensional blood flow model, ESAIM: Proceedings, vol.14, pp.174-200, 2005. ,
DOI : 10.1051/proc:2005014
URL : https://hal.archives-ouvertes.fr/hal-00700366
Erratum of article ???Reduced-order Unscented Kalman Filtering with application to parameter identification in large-dimensional systems???, ESAIM: Control, Optimisation and Calculus of Variations, vol.17, issue.2, pp.406-409, 2011. ,
DOI : 10.1051/cocv/2011001
Reduced-order Unscented Kalman Filtering with application to parameter identification in large-dimensional systems, ESAIM: Control, Optimisation and Calculus of Variations, vol.17, issue.2, pp.380-405, 2011. ,
DOI : 10.1051/cocv/2010006
URL : https://hal.archives-ouvertes.fr/inria-00550104
Joint state and parameter estimation for distributed mechanical systems, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.6-8, pp.659-677, 2008. ,
DOI : 10.1016/j.cma.2007.08.021
URL : https://hal.archives-ouvertes.fr/hal-00175623
Filtering for distributed mechanical systems using position measurements: perspectives in medical imaging, Inverse Problems, vol.25, issue.3, p.35010, 2009. ,
DOI : 10.1088/0266-5611/25/3/035010
URL : https://hal.archives-ouvertes.fr/hal-00358914
External tissue support and fluid???structure simulation in blood flows, Biomechanics and Modeling in Mechanobiology, vol.31, issue.3, pp.1-18, 2011. ,
DOI : 10.1007/s10237-011-0289-z
URL : https://hal.archives-ouvertes.fr/hal-00701801
Nonlinear-transformation-field to build moving meshes for patient specific blood flow simulations (eds) ECCOMAS CFD Navon I (2009) Data assimilation for numerical weather prediction: A review In: Data assimilation for atmospheric, oceanic, hydrologic applications A variational approach for estimating the compliance of the cardiovascular tissue: An inverse fluid-structure interaction problem, SIAM J Sc Comp, vol.33, issue.3, pp.1181-1211, 2006. ,
Heuristically driven front propagation for fast geodesic extraction, International Journal for Computational Vision and Biomechanics, vol.1, issue.1, pp.55-67, 2008. ,
Stochastic Methods for Sequential Data Assimilation in Strongly Nonlinear Systems, Monthly Weather Review, vol.129, issue.5, pp.1194-1207, 2001. ,
DOI : 10.1175/1520-0493(2001)129<1194:SMFSDA>2.0.CO;2
URL : https://hal.archives-ouvertes.fr/inria-00073082
Filtres de Kalman singuliersévolutifssinguliersévolutifs pour l'assimilation de données en, 1998. ,
