A nudging-based data assimilation method: the Back and Forth Nudging (BFN) algorithm. Nonlinear Processes In Geophysics, pp.305-319, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00327422
Filtrage Optimal des Systèmes Linéaires, 1971. ,
Sequential parameter estimation for fluidstructure problems. application to hemodynamics, Int. J. Num. Meth. Biomedical Engng., published online, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00603399
Estimation of tissue contractility from cardiac cine-mri using a biomechanical heart model, Biomechanics and Modeling in Mechanobiology, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00654541
Nonlinear Least Squares for Inverse Problems, 2010. ,
DOI : 10.1007/978-90-481-2785-6
A variational data assimilation procedure for the incompressible Navier-Stokes equations in hemodynamics, Journal of Scientific Computing, pp.1-20, 2011. ,
Personalization of Cardiac Motion and Contractility From Images Using Variational Data Assimilation, IEEE Transactions on Biomedical Engineering, vol.59, issue.1, pp.20-24, 2012. ,
DOI : 10.1109/TBME.2011.2160347
URL : https://hal.archives-ouvertes.fr/inria-00616183
Sequential data assimilation with a nonlinear quasi-geostrophic model using Monte Carlo methods to forecast error statistics, Journal of Geophysical Research, vol.109, issue.Part 4, pp.10143-10162, 1994. ,
DOI : 10.1029/94JC00572
A Galerkin strategy with Proper Orthogonal Decomposition for parameter-dependent problems ??? Analysis, assessments and applications to parameter estimation, ESAIM: Mathematical Modelling and Numerical Analysis, vol.47, issue.6, 2012. ,
DOI : 10.1051/m2an/2013090
URL : https://hal.archives-ouvertes.fr/hal-00834397
A simplified reduced order Kalman filtering and application to altimetric data assimilation in Tropical Pacific, Journal of Marine Systems, vol.36, issue.1-2, pp.101-127, 2002. ,
DOI : 10.1016/S0924-7963(02)00129-X
Constitutive Parameter Estimation Methodology Using Tagged-MRI Data, Proceedings of FIMH'11, 2011. ,
DOI : 10.1109/42.414605
A new method for the nonlinear transformation of means and covariances in filters and estimators, IEEE Transactions on Automatic Control, vol.45, issue.3, pp.447-482, 2000. ,
DOI : 10.1109/9.847726
Efficient probabilistic model personalization integrating uncertainty on data and parameters: Application to Eikonal-Diffusion models in cardiac electrophysiology, Progress in Biophysics and Molecular Biology, vol.107, issue.1, pp.134-146, 2011. ,
DOI : 10.1016/j.pbiomolbio.2011.07.002
URL : https://hal.archives-ouvertes.fr/inria-00616198
Determining the State of a Linear with Observers of Low Dynamic Order, 1963. ,
Filtering-based Data Assimilation for Second-Order Hyperbolic PDEs. Applications in Cardiac Mechanics, 2008. ,
URL : https://hal.archives-ouvertes.fr/tel-00358582
Reduced-order Unscented Kalman Filtering with application to parameter identification in large-dimensional systems, COCV, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00550104
Erratum of article ???Reduced-order Unscented Kalman Filtering with application to parameter identification in large-dimensional systems???, ESAIM: Control, Optimisation and Calculus of Variations, vol.17, issue.2, pp.406-409, 2011. ,
DOI : 10.1051/cocv/2011001
Joint state and parameter estimation for distributed mechanical systems, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.6-8, pp.659-677, 2008. ,
DOI : 10.1016/j.cma.2007.08.021
URL : https://hal.archives-ouvertes.fr/hal-00175623
Filtering for distributed mechanical systems using position measurements: perspectives in medical imaging, Inverse Problems, vol.25, issue.3, p.35010, 2009. ,
DOI : 10.1088/0266-5611/25/3/035010
URL : https://hal.archives-ouvertes.fr/hal-00358914
Building maps of local apparent conductivity of the epicardium with a 2-D electrophysiological model of the heart, IEEE Transactions on Biomedical Engineering, vol.53, issue.8, pp.531457-1466, 2006. ,
DOI : 10.1109/TBME.2006.877794
URL : https://hal.archives-ouvertes.fr/inria-00614992
Stochastic Methods for Sequential Data Assimilation in Strongly Nonlinear Systems, Monthly Weather Review, vol.129, issue.5, pp.194-195, 2001. ,
DOI : 10.1175/1520-0493(2001)129<1194:SMFSDA>2.0.CO;2
URL : https://hal.archives-ouvertes.fr/inria-00073082
A singular evolutive extended Kalman filter for data assimilation in oceanography, Journal of Marine systems, vol.16, pp.3-4323, 1998. ,
Coupled personalization of cardiac electrophysiology models for prediction of ischaemic ventricular tachycardia, Interface Focus, vol.48, issue.12, pp.396-407, 2011. ,
DOI : 10.1016/j.jacc.2006.07.062
URL : https://hal.archives-ouvertes.fr/inria-00616188
euHeart: personalized and integrated cardiac care using patient-specific cardiovascular modelling, Interface Focus, vol.41, issue.10, pp.349-364, 2011. ,
DOI : 10.1016/j.jbiomech.2008.04.035
URL : https://hal.archives-ouvertes.fr/inria-00616189
A reduced-rank square root filtering framework for noninvasive functional imaging of volumetric cardiac electrical activity, 2009 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.533-536, 2009. ,
DOI : 10.1109/ICASSP.2009.4959638
Myocardial transversely isotropic material parameter estimation from in-silico measurements based on a reduced-order unscented Kalman filter, Journal of the Mechanical Behavior of Biomedical Materials, vol.4, issue.7, pp.1090-1102, 2011. ,
DOI : 10.1016/j.jmbbm.2011.03.018
An automatic data assimilation framework for patient-specific myocardial mechanical parameter estimation. Functional Imaging and Modeling of the Heart, pp.392-400, 2011. ,
