Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : A solution to the problem of stabilizing nonlinear systems with input with a constant pointwise delay and state- dependent sampling is proposed. It relies on a recursive construction of the sampling instants and on a recent variant of the classical reduction model approach. State feedbacks without distributed terms are obtained. A lower bound on the maximal allowable delay is determined via a Lyapunov- Krasovskii analysis.
Frédéric Mazenc, Claudio de Persis, Mounir Bekaïk. Practical stabilization of nonlinear systems with state-dependent sampling and retarded inputs.. 2012 American Control Conference, Jun 2012, Montreal, Canada. ⟨hal-00761269⟩
