Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : A problem of state feedback stabilization of time-varying feedforward systems with a pointwise delay in the input is solved. The approach relies on a time-varying change of coordinates and Lyapunov-Krasovskii functionals. The result applies for any given constant delay, and provides uniformly globally asymptotically stabilizing controllers of arbitrarily small amplitude. The closed-loop systems enjoy input-to-state stability properties with respect to additive uncertainty on the controllers. The work is illustrated through a tracking problem for a model for high level formation flight of unmanned air vehicles.
Frédéric Mazenc, Michael Malisoff. Asymptotic Stabilization for Feedforward Systems with Delayed Feedback. Automatica, Elsevier, 2013, 49 (3), pp.780-787. ⟨10.1016/j.automatica.2012.11.049⟩. ⟨hal-00761317⟩
