Conference papers
A cooperative conjugate gradient method for linear systems permitting multithread implementation of low complexity
Abstract : This paper proposes a generalization of the conjugate gradient (CG) method used to solve the equation $Ax=b$ for a symmetric positive definite matrix $A$ of large size $n$. The generalization consists of permitting the scalar control parameters (= stepsizes in gradient and conjugate gradient directions) to be replaced by matrices, so that multiple descent and conjugate directions are updated simultaneously. Implementation involves the use of multiple agents or threads and is referred to as cooperative CG (cCG), in which the cooperation between agents resides in the fact that the calculation of each entry of the control parameter matrix now involves information that comes from the other agents. For a sufficiently large dimension $n$, the use of an optimal number of cores gives the result that the multithread implementation has worst case complexity $O(n^{2+1/3})$ in exact arithmetic. Numerical experiments, that illustrate the interest of theoretical results, are carried out on a multicore computer
Complete list of metadatas
https://hal.inria.fr/hal-00761333
Contributor : Pierre-Alexandre Bliman <>
Submitted on : Wednesday, December 5, 2012 - 12:26:53 PM
Last modification on : Monday, May 18, 2020 - 4:50:34 PM
Links full text
Identifiers
Collections
Citation
Amit Bhaya, Pierre-Alexandre Bliman, Guilherme Niedu, Fernando Pazos. A cooperative conjugate gradient method for linear systems permitting multithread implementation of low complexity. CDC 2012 - 51st IEEE Conference on Decision and Control, Dec 2012, Maui, HI, United States. pp.638-643, ⟨10.1109/CDC.2012.6426341⟩. ⟨hal-00761333⟩
Share
Metrics
Record views
244
