Copy Elimination on Data Dependence Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Register allocation recently regained much interest due to new decoupled strategies that split the problem into separate phases: spilling, register assignment, and copy elimination. A common assumption of existing copy elimination approaches is that the original ordering of the instructions in the program is not changed. This work presents an extension of a local recoloring technique called Parallel Copy Motion. We perform code motion on data dependence graphs in order to eliminate useless copies and reorder instructions, while at the same time a valid register assignment is preserved. Our results show that even after traditional register allocation with coalescing our technique is able to eliminate an additional 3% (up to 9%) of the remaining copies and reduce the weighted costs of register copies by up to 25% for the SPECINT 2000 benchmarks. In comparison to Parallel Copy Motion, our technique removes 11% (up to 20%) more copies and up to 39% more of the copy costs.
Fichier non déposé
hal-00761499 , version 1 (05-12-2012)
Florian Brandner, Quentin Colombet. Copy Elimination on Data Dependence Graphs. 27th Annual ACM Symposium on Applied Computing (SAC'12), Mar 2012, Trento, Italy. pp.1916-1918, ⟨10.1145/2245276.2232091⟩. ⟨hal-00761499⟩
84 Consultations
0 Téléchargements
