Exponentially Stable Interval Observers for Linear Systems with Delay. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2012
This paper focuses on the analysis and the design of families of interval observers for linear systems with a point-wise delay. First, it is proved that classical interval observers for systems without delays are not robust with respect to the presence of delays, no matter how small delays are. Next, it is shown that, in general, for linear systems with delay, the classical interval observers endowed with a point-wise delay are unstable. A new type of design of interval observers enabling to circumvent these obstacles is proposed. It provides with framers that incorporate distributed delay terms. The proposed interval observers are assessed through a non-linear biotechnological model.
Automatique
2012_Mazenc_SIAM_1.pdf (318.05 Ko) Télécharger le fichier
hal-00761603 , version 1 (29-05-2020)
Frédéric Mazenc, Silviu-Iulian Niculescu, Olivier Bernard. Exponentially Stable Interval Observers for Linear Systems with Delay.. SIAM Journal on Control and Optimization, 2012, 50 (1), pp.286-305. ⟨10.1137/100812124⟩. ⟨hal-00761603⟩
305 Consultations
268 Téléchargements
