Stabilization and tracking control for an extended Heisenberg system with a drift - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2005
In this paper, we present sliding mode control algorithms, that are designed to practically stabilize (which means that the system state is stabilized to an ɛɛ neighborhood of the origin) the perturbed multidimensional Heisenberg system (therefore, with a drift) with additional two multidimensional integrators in the control inputs path. This result is then used to solve a tracking problem for the class of system which unperturbed model fails Brockett's necessary condition for the existence of a continuous, time independent feedback law.
Automatique
hal-00762279 , version 1 (06-12-2012)
Serguey Drakunov, Thierry Floquet, Wilfrid Perruquetti. Stabilization and tracking control for an extended Heisenberg system with a drift. Systems and Control Letters, 2005, 54 (5), pp.435-445. ⟨10.1016/j.sysconle.2004.09.014⟩. ⟨hal-00762279⟩
54 Consultations
0 Téléchargements
