Invalidation of the structure of genetic network dynamics: a geometric approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2012
This work concerns the identification of the structure of a genetic network model from measurements of gene product concentrations and synthesis rates. In earlier work, we developed a data preprocessing algorithm that is able to reject many hypotheses on the network structure by testing certain monotonicity properties for a wide family of network models. Here, we develop a geometric interpretation of the method. Then, for a relevant subclass of genetic network models, we extend our approach to the combined testing of monotonicity and convexity-like properties associated with the network structures. The theoretical aspects and practical performance of the enhanced methods are illustrated by way of numerical results.
Invalidation_of_the_structure_of_genetic_network_dynamics_-_A_gemoetric_approach.pdf (658.34 Ko) Télécharger le fichier
hal-00762592 , version 1 (07-12-2012)
Ricardo Porreca, Eugenio Cinquemani, John Lygeros, Giancarlo Ferrari-Trecate. Invalidation of the structure of genetic network dynamics: a geometric approach. International Journal of Robust and Nonlinear Control, 2012, Special Issue: System Identification for Biological Systems, 22 (10), pp.1140-1156. ⟨10.1002/rnc.2799⟩. ⟨hal-00762592⟩
185 Consultations
160 Téléchargements
