Occupational risk factors associated with soft tissue disorders of the shoulder: a review of recent investigations in the literature, Ergonomics, vol.25, issue.6, pp.36-697, 1993. ,
DOI : 10.1080/00140138908966080
Musculoskeletal disorders and workplace factors : a critical review of epidemiologic evidence for work-related musculoskeletal disorders of the neck, upper extremity and low back, 1997. ,
Time to task failure in shoulder elevation is associated to increase in amplitude and to spatial heterogeneity of upper trapezius mechanomyographic signals, European Journal of Applied Physiology, vol.9, issue.3, pp.325-333, 2008. ,
DOI : 10.1007/s00421-007-0589-2
Changes in the degree of motor variability associated with experimental and chronic neck???shoulder pain during a standardised repetitive arm movement, Experimental Brain Research, vol.62, issue.1, pp.689-698, 2008. ,
DOI : 10.1007/s00221-007-1199-2
Shoulder muscle coordination under chronic and experimental neckshoulder pain: An occupational pain study, European Journal of Applied Physiology, pp.79-127, 1999. ,
Physical workload during manual and mechanical deboning of poultry, International Journal of Industrial Ergonomics, vol.29, issue.2, pp.107-115, 2002. ,
DOI : 10.1016/S0169-8141(01)00051-8
A system for the measurement of grip forces and applied moments during hand tool use, Applied Ergonomics, vol.32, issue.3, pp.271-279, 2001. ,
DOI : 10.1016/S0003-6870(00)00062-4
Human Factors in engineering and design, 1987. ,
Cutting moments and grip forces in meat cutting operations and the effect of knife sharpness, Applied Ergonomics, vol.34, issue.4, pp.375-382, 2003. ,
DOI : 10.1016/S0003-6870(03)00041-3
Functional subdivision of the upper trapezius muscle during low-level activation, European Journal of Applied Physiology, vol.76, issue.4, pp.335-339, 1997. ,
DOI : 10.1007/s004210050257
Electromechanical delay in human skeletal muscle under concentric and eccentric contractions, European Journal of Applied Physiology and Occupational Physiology, vol.36, issue.3, pp.159-163, 1979. ,
DOI : 10.1007/BF00431022
Electromechanical delay during knee extensor contractions, Medicine & Science in Sports & Exercise, vol.23, issue.10, pp.1187-1193, 1991. ,
DOI : 10.1249/00005768-199110000-00013
The electro-mechanical delay of the erector spinae muscle: influence of rate of force development, fatigue and electrode location, European Journal of Applied Physiology and Occupational Physiology, vol.60, issue.3-4, pp.216-222, 1991. ,
DOI : 10.1007/BF00233851
Towards optimal multi-channel EMG electrode configurations in muscle force estimation: a high density EMG study, Journal of Electromyography and Kinesiology, vol.15, issue.1, pp.1-11, 2005. ,
DOI : 10.1016/j.jelekin.2004.06.008
Methodological aspects of SEMG recordings for force estimation ??? A tutorial and review, Journal of Electromyography and Kinesiology, vol.20, issue.3, pp.375-387, 2010. ,
DOI : 10.1016/j.jelekin.2009.08.005
Measurement and evaluation of postural load in occupational work situations, European Journal of Applied Physiology and Occupational Physiology, vol.55, issue.Suppl 3, pp.291-304, 1988. ,
DOI : 10.1007/BF00635987
Active biofeedback changes the spatial distribution of upper trapezius muscle activity during computer work, European Journal of Applied Physiology, vol.82, issue.2, pp.415-423, 2010. ,
DOI : 10.1007/s00421-010-1515-6
How should we normalize electromyograms obtained from healthy participants? what we have learned from over 25 years of research, Journal of Electromyography and Kinesiology, vol.20, issue.6, pp.1023-1035, 2010. ,
The change in spatial distribution of upper trapezius muscle activity is correlated to contraction duration, Journal of Electromyography and Kinesiology, vol.18, issue.1, pp.16-25, 2008. ,
DOI : 10.1016/j.jelekin.2006.08.005
Role of Cocontraction in Arm Movement Accuracy, Journal of Neurophysiology, vol.89, issue.5, pp.2396-2405, 2003. ,
DOI : 10.1152/jn.01020.2002
Optimal Impedance Control for Task Achievement in the Presence of Signal-Dependent Noise, Journal of Neurophysiology, vol.92, issue.2, pp.1199-1215, 2004. ,
DOI : 10.1152/jn.00519.2003
Multijoint muscle regulation mechanisms examined by measured human arm stiffness and emg signals, Journal of Neurophysiology, vol.81, issue.4, pp.1458-1468, 1999. ,
Independent control of joint stiffness in the framework of the equilibrium-point hypothesis, Biological Cybernetics, vol.47, issue.4, pp.377-384, 1992. ,
DOI : 10.1007/BF02414893
Compensation for mechanically unstable loading in voluntary wrist movement, Experimental Brain Research, vol.94, issue.3, pp.522-532, 1994. ,
DOI : 10.1007/BF00230210
Adaptation to Stable and Unstable Dynamics Achieved By Combined Impedance Control and Inverse Dynamics Model, Journal of Neurophysiology, vol.90, issue.5, pp.3270-3282, 2003. ,
DOI : 10.1152/jn.01112.2002
Functional significance of stiffness in adaptation of multijoint arm movements to stable and unstable dynamics, Experimental Brain Research, vol.151, issue.2, pp.145-157, 2003. ,
DOI : 10.1007/s00221-003-1443-3
Co-activation of the elbow antagonist muscles is not affected by the speed of movement in isokinetic exercise, Muscle and Nerve, pp.191-199, 2006. ,
Effect of elbow joint angle on force???EMG relationships in human elbow flexor and extensor muscles, Journal of Electromyography and Kinesiology, vol.18, issue.5, pp.760-770, 2008. ,
DOI : 10.1016/j.jelekin.2007.03.006
Electromyographic correlates of learning an internal model of reaching movements, The Journal of Neuroscience, vol.19, issue.19, pp.8573-8588, 1999. ,
Short-and longterm changes in joint co-contraction associated with motor learning as revealed from surface emg, Journal of Neurophysiology, vol.88, issue.2, pp.991-1004, 2002. ,
Changes in the amount and structure of motor variability during a deboning process are associated with work experience and neck???shoulder discomfort, Applied Ergonomics, vol.40, issue.5, pp.887-894, 2009. ,
DOI : 10.1016/j.apergo.2008.12.006
The size of cycle-to-cycle variability in biomechanical exposure among butchers performing a standardised cutting task, Ergonomics, vol.38, issue.7, pp.51-1078, 2008. ,
DOI : 10.1016/0169-8141(92)90051-Z
Meat Cutting Tasks Analysis Using 3D Instrumented Knife and Motion Capture, 15th Nordic-Baltic Conference on Biomedical Engineering and Medical Physics, pp.144-147, 2011. ,
DOI : 10.1007/978-3-642-21683-1_36
URL : https://hal.archives-ouvertes.fr/hal-00640202
Trend Validation of a Musculoskeletal Model with a Workstation Design Parameter, proceedings of : Technical Group on Computer Simulation Symposium, pp.83-84, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00640206
Inverse dynamics method using optimization techniques for the estimation of muscles forces involved in the elbow motion, International Journal on Interactive Design and Manufacturing (IJIDeM), vol.75, issue.2, pp.227-235, 2009. ,
DOI : 10.1007/s12008-009-0078-4
URL : https://hal.archives-ouvertes.fr/inria-00442353
From motion capture to muscle forces in the human elbow aimed at improving the ergonomics of workstations, Virtual and Physical Prototyping, vol.75, issue.3, pp.113-122, 2010. ,
DOI : 10.1109/IEMBS.1996.646515
URL : https://hal.archives-ouvertes.fr/inria-00535792
On validation of multibody musculoskeletal models, Proceedings of the Institution of Mechanical Engineers, Part H: Journal of Engineering in Medicine, vol.226, issue.2, pp.82-94, 2012. ,
DOI : 10.1177/0954411911431516
A distributed approach for access and visibility task under ergonomic constraints with a manikin in a virtual reality environment, Proceedings 10th IEEE International Workshop on Robot and Human Interactive Communication. ROMAN 2001 (Cat. No.01TH8591), pp.32-37, 2001. ,
DOI : 10.1109/ROMAN.2001.981873
URL : https://hal.archives-ouvertes.fr/hal-00162576
