Modeling Ice-Sheet Flow, Science, vol.336, issue.6081, pp.551-552 ,
DOI : 10.1126/science.1220530
Initialization of ice-sheet forecasts viewed as an inverse Robin problem, Journal of Glaciology, vol.56, issue.197, pp.527-533, 2010. ,
DOI : 10.3189/002214310792447699
A new ice thickness and bed data set for the Greenland ice sheet: 1. Measurement, data reduction, and errors, Journal of Geophysical Research: Atmospheres, vol.48, issue.2, pp.33773-33780, 2001. ,
DOI : 10.1029/2001JD900054
Higher surface mass balance of the Greenland ice 10 sheet revealed by high-resolution climate modeling, Geophys. Res. Lett, pp.10-1029, 2009. ,
A three-dimensional full Stokes model of the grounding line dynamics: effect of a pinning point beneath the ice shelf, The Cryosphere, pp.101-112, 2012. ,
Estimation of the Greenland ice sheet surface mass balance for the 20th and 21st centuries, The Cryosphere, pp.117-129, 2008. ,
Anisotropic mesh adaptation for CFD computations, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.48-49, pp.5068-5082, 2005. ,
DOI : 10.1016/j.cma.2004.11.025
Some numerical experiments with variable-storage quasi-Newton algorithms, Mathematical Programming, vol.11, issue.2, pp.407-435, 1989. ,
DOI : 10.1007/BF01589113
The Creep of Polycrystalline Ice, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.228, issue.1175, pp.519-538, 1955. ,
DOI : 10.1098/rspa.1955.0066
Data assimilation using a hybrid ice flow model, The Discussion Paper | Discussion Paper | Discussion Paper | Discussion Paper | Pralong Bayesian estimation of basal conditions on Rutford Ice Stream, West Antarctica, from surface data, J. Glaciol, vol.57, pp.315-324, 2011. ,
Committed sea-level rise for the next century from Greenland ice sheet dynamics during the past decade, Proceedings of the National Academy of Sciences, vol.108, issue.22, pp.8978-8983, 2011. ,
DOI : 10.1073/pnas.1017313108
Extensive dynamic thinning on the margins of the Greenland and Antarctic ice sheets, Nature, vol.302, issue.7266, pp.971-97510, 2009. ,
DOI : 10.1038/nature08471
Changes in the Velocity Structure of the Greenland Ice Sheet, Science, vol.311, issue.5763, pp.986-990, 2006. ,
DOI : 10.1126/science.1121381
Acceleration of the contribution of the Greenland and Antarctic ice sheets to sea level rise, Geophysical Research Letters, vol.36, issue.2, pp.10-1029, 2011. ,
DOI : 10.1029/2011GL046583
Sensitivity of basal conditions in an inverse 15 model: Vestfonna Ice-Cap, Nordaustlandet/Svalbard, The Cryosphere Discuss, pp.427-46710, 2012. ,
Ice-sheet acceleration driven by melt supply variability, Nature, vol.115, issue.7325, pp.803-806, 2010. ,
DOI : 10.1038/nature09618
Revisiting Greenland ice sheet mass loss observed by GRACE, Journal of Geophysical Research, vol.51, issue.175, pp.2407-2417, 2011. ,
DOI : 10.1029/2009JB006847
Simulations of the Greenland ice sheet 100 years into the future with the full Stokes model Elmer/Ice, Journal of Glaciology, vol.58, issue.209, pp.427-440103189, 2012. ,
DOI : 10.3189/2012JoG11J177
Contribution of Working Group I to the Fourth Assessment Report of the Intergovernmental Panel on Climate Change, 2007. ,
CLIMATE CHANGE: Rethinking Ice Sheet Time Scales, Science, vol.315, issue.5818, pp.1508-1510, 2007. ,
DOI : 10.1126/science.1140469
CLIMATE CHANGE: Why Is It Hard to Predict the Future of Ice Sheets?, Science, vol.315, issue.5818, pp.1503-1504, 2007. ,
DOI : 10.1126/science.1141111
GRACE observes small-scale mass loss in Greenland, Geophysical Research Letters, vol.51, issue.175, pp.10-1029, 2008. ,
DOI : 10.1029/2008GL034816
