Improving throughput and fairness by reducing exposed and hidden nodes in 802, IEEE Trans. Mobile Computing, vol.11, issue.7 1, pp.34-49, 2008. ,
Determining the end-to-end throughput capacity in multi-hop networks: methodology and applications, Proc. ACM SIGMETRICS, pp.39-50, 2006. ,
On the fairness of large CSMA networks, IEEE J. Selected Areas in Communications, pp.1093-1104, 2009. ,
Comparative study of hidden node problem and solution using different techniques and protocols, J. of Computing, vol.2, issue.3, 2010. ,
