New interface
Reports (Research report)
Doubly sparse models for multiple filter estimation in sparse echoic environments
Prasad Sudhakar 1 Simon Arberet 2 Rémi Gribonval 1 Pierre Vandergheynst 2
1 METISS - Speech and sound data modeling and processing
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : We consider the estimation of multiple time-domain sparse filters from echoic mixtures of several unknown sources, when the sources are sparse in the time-frequency domain. We propose a sparse filter estimation framework consisting of two steps: a) a clustering step to group the time-frequency points of mixtures where only one source is active, for each source; b) a convex optimisation step to estimate the filters based on a time-frequency domain cross-relation. We propose a new wideband formulation of a frequency domain cross-relation, besides the one based on classical narrowband approximation. The solutions of the convex optimisation problem, formed using the cross-relation, are characterised. Numerical evaluation shows the benefit of using the wideband cross-relation for sparse echoic filter estimation. Further, the potential of the proposed framework for blind estimation of sparse echoic filters is demonstrated in a controlled experimental setting where in the proposed approach outperforms the state of the art blind filter estimation techniques, when the filters are sufficiently sparse.
Complete list of metadata
Cited literature [42 references]  Display  Hide  Download
https://hal.inria.fr/hal-00763226
Contributor : Prasad Sudhakar Connect in order to contact the contributor
Submitted on : Monday, December 10, 2012 - 12:45:50 PM
Last modification on : Thursday, October 27, 2022 - 3:45:22 AM
Long-term archiving on: : Monday, March 11, 2013 - 12:25:18 PM
articleSigPro.pdf
Identifiers
  • HAL Id : hal-00763226, version 1
Citation
Prasad Sudhakar, Simon Arberet, Rémi Gribonval, Pierre Vandergheynst. Doubly sparse models for multiple filter estimation in sparse echoic environments. [Research Report] 2012. ⟨hal-00763226⟩
Share
Metrics
Record views
268
Files downloads
156
