Independent component analysis, A new concept?, Signal Processing, vol.36, issue.3, pp.287-314, 1994. ,
DOI : 10.1016/0165-1684(94)90029-9
URL : https://hal.archives-ouvertes.fr/hal-00417283
Blind separation of disjoint orthogonal signals: demixing N sources from 2 mixtures, 2000 IEEE International Conference on Acoustics, Speech, and Signal Processing. Proceedings (Cat. No.00CH37100), pp.2985-2988 ,
DOI : 10.1109/ICASSP.2000.861162
Blind separation of dependent sources using the "time-frequency ratio of mixtures" approach, Seventh International Symposium on Signal Processing and Its Applications, 2003. Proceedings., pp.81-84 ,
DOI : 10.1109/ISSPA.2003.1224820
Temporal and time-frequency correlation-based blind source separation methods. Part I: Determined and underdetermined linear instantaneous mixtures, Signal Processing, vol.87, issue.3, pp.374-407, 2007. ,
DOI : 10.1016/j.sigpro.2006.05.012
URL : https://hal.archives-ouvertes.fr/hal-00270884
A Robust Method to Count and Locate Audio Sources in a Multichannel Underdetermined Mixture, IEEE Transactions on Signal Processing, vol.58, issue.1, p.121, 2010. ,
DOI : 10.1109/TSP.2009.2030854
URL : https://hal.archives-ouvertes.fr/inria-00489529
A survey of convolutive blind source separation methods, 2007. ,
A Robust and Precise Method for Solving the Permutation Problem of Frequency-Domain Blind Source Separation, IEEE Transactions on Speech and Audio Processing, vol.12, issue.5, pp.530-538, 2004. ,
DOI : 10.1109/TSA.2004.832994
Permutation Alignment for Frequency Domain ICA Using Subspace Beamforming Methods, Proc. of Independent Component Analysis and Blind Signal Separation, pp.669-676 ,
DOI : 10.1007/978-3-540-30110-3_85
A beamforming approach to permutation alignment for multichannel frequency-domain blind source separation, Proc. of ICASSP, pp.881-884 ,
Permutation inconsistency in blind speech separation: investigation and solutions, IEEE Transactions on Speech and Audio Processing, vol.13, issue.1, pp.1-13, 2005. ,
DOI : 10.1109/TSA.2004.834441
Blind separation of convolved mixtures in the frequency domain, Neurocomputing, vol.22, issue.1-3, pp.21-34, 1998. ,
DOI : 10.1016/S0925-2312(98)00047-2
Convolutive blind separation of non-stationary sources, IEEE Transactions on Speech and Audio Processing, vol.8, issue.3, pp.320-327, 2000. ,
DOI : 10.1109/89.841214
An approach to blind source separation based on temporal structure of speech signals, Neurocomputing, vol.41, issue.1-4, 2001. ,
DOI : 10.1016/S0925-2312(00)00345-3
A novel method for permutation correction in frequency-domain in blind separation of speech mixtures, Independent Component Analysis and Blind Signal Separation, pp.807-815, 2004. ,
A Sparsity-Based Method to Solve Permutation Indeterminacy in Frequency-Domain Convolutive Blind Source Separation, Proc. of the International Conference on Independent Component Analysis and Signal Separation, pp.338-345 ,
DOI : 10.1002/cpa.20131
URL : https://hal.archives-ouvertes.fr/inria-00544760
A deterministic approach to blind identification of multi-channel FIR systems, Proc. of ICASSP, pp.581-584 ,
Subspace methods for the blind identification of multichannel FIR filters, IEEE Transactions on Signal Processing, vol.43, issue.2, p.516, 1995. ,
DOI : 10.1109/78.348133
A least-squares approach to blind channel identification, IEEE Transactions on Signal Processing, vol.43, pp.2982-2993, 1995. ,
A least squares component normalization approach to blind channel identification, 1999 IEEE International Conference on Acoustics, Speech, and Signal Processing. Proceedings. ICASSP99 (Cat. No.99CH36258), pp.1797-1800 ,
DOI : 10.1109/ICASSP.1999.758269
Adaptive multi-channel least mean square and Newton algorithms for blind channel identification, Signal Processing, vol.82, issue.8, pp.1127-1138, 2002. ,
DOI : 10.1016/S0165-1684(02)00247-5
Abed-Meraim, Blind SIMO channel identification using a sparsity criterion, Proc. of SPAWC, pp.271-275 ,
Blind Separation of Speech Mixtures via Time-Frequency Masking, IEEE Transactions on Signal Processing, vol.52, issue.7, pp.1830-1847, 2004. ,
DOI : 10.1109/TSP.2004.828896
Grouping Separated Frequency Components by Estimating Propagation Model Parameters in Frequency-Domain Blind Source Separation, IEEE Transactions on Audio, Speech and Language Processing, vol.15, issue.5, pp.1592-1604, 2007. ,
DOI : 10.1109/TASL.2007.899218
Servì ere, Blind separation of convolutive mixture of speech signals, Proc. of EUSIPCO ,
Blind separation of convolutive audio mixtures using nonstationarity, Proceedings of ICA, pp.975-980 ,
Underdetermined Convolutive Blind Source Separation via Time–Frequency Masking, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.1, pp.101-116, 2010. ,
DOI : 10.1109/TASL.2009.2024380
Underdetermined Convolutive Blind Source Separation via Frequency Bin-Wise Clustering and Permutation Alignment, IEEE Transactions on Audio, Speech, and Language Processing, vol.19, issue.3, pp.516-527, 2011. ,
DOI : 10.1109/TASL.2010.2051355
Under-Determined Reverberant Audio Source Separation Using a Full-Rank Spatial Covariance Model, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.7, pp.1830-1840, 2010. ,
DOI : 10.1109/TASL.2010.2050716
URL : https://hal.archives-ouvertes.fr/inria-00435807
Nonnegative matrix factorization and spatial covariance model for under-determined reverberant audio source separation, 10th International Conference on Information Science, Signal Processing and their Applications (ISSPA 2010), pp.1-4 ,
DOI : 10.1109/ISSPA.2010.5605570
URL : https://hal.archives-ouvertes.fr/inria-00541436
Beyond the Narrowband Approximation: Wideband Convex Methods for Under-Determined Reverberant Audio Source Separation, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.7, pp.1818-1829, 2010. ,
DOI : 10.1109/TASL.2010.2050089
URL : https://hal.archives-ouvertes.fr/hal-00435897
Sparse equalization for real-time digital underwater acoustic communications, 'Challenges of Our Changing Global Environment'. Conference Proceedings. OCEANS '95 MTS/IEEE, pp.1417-1422 ,
DOI : 10.1109/OCEANS.1995.528671
Estimation of Rapidly Time-Varying Sparse Channels, IEEE Journal of Oceanic Engineering, vol.32, issue.4, pp.927-939, 2007. ,
DOI : 10.1109/JOE.2007.906409
Tap-selectable decision-feedback equalization, IEEE Transactions on Communications, vol.45, issue.12, pp.1497-1500, 1997. ,
DOI : 10.1109/26.650219
A Matching-Pursuit/GSIC-Based Algorithm for DS-CDMA Sparse-Channel Estimation, IEEE Signal Processing Letters, vol.11, issue.1, pp.12-15, 2004. ,
DOI : 10.1109/LSP.2003.819349
Deconvolution of marine seismic data using the l1 norm, Geophysical Journal International, vol.72, issue.1, pp.93-100, 1983. ,
DOI : 10.1111/j.1365-246X.1983.tb02806.x
Blind separation of underdetermined convolutive mixtures using their time -frequency representation, IEEE Transactions on ALSP, vol.15, pp.1540-1550, 2007. ,
A Wavelet Tour of Signal Processing, Third Edition: The Sparse Way, 2008. ,
Double Sparsity: Towards Blind Estimation of Multiple Channels, LVA/ICA, pp.571-578 ,
DOI : 10.1007/978-3-642-15995-4_71
URL : https://hal.archives-ouvertes.fr/inria-00537756
CVX: Matlab software for disciplined convex programming, version 1, 2011. ,
Strict identifiability of multiple fir channels driven by an unknown arbitrary sequence, Signal Processing, IEEE Transactions on, vol.44, pp.756-759, 1996. ,
The generalized correlation method for estimation of time delay, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.24, issue.4, pp.320-327, 1976. ,
DOI : 10.1109/TASSP.1976.1162830
