Improving Premise Structure in Evolving Takagi-Sugeno Neuro-Fuzzy Classifiers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Abdullah Almaksour
  • Fonction : Auteur
  • PersonId : 872000
Eric Anquetil
We present in this paper a new method for the design of evolving neuro-fuzzy classifiers. The presented approach is based on a first-order Takagi-Sugeno neuro-fuzzy model. We propose a modification on the premise structure in this model and we provide the necessary learning formulas, with no problem-dependent parameters. We demonstrate by the experimental results the positive effect of this modification on the overall classification performance
AlmaksourICMLA10.pdf (938.5 Ko) Télécharger le fichier
hal-00763296 , version 1 (10-12-2012)
  • HAL Id : hal-00763296 , version 1
Abdullah Almaksour, Eric Anquetil. Improving Premise Structure in Evolving Takagi-Sugeno Neuro-Fuzzy Classifiers. International Conference on Machine Learning and Applications ICMLA, 2010, washington, United States. ⟨hal-00763296⟩
205 Consultations
131 Téléchargements
