Journal articles
Embedding Polychrony into Synchrony
Abstract : This article presents an embedding of polychronous programs into synchronous ones. Due to this embedding, it is not only possible to deepen the understanding of these different models of computation but more importantly, it is possible to transfer compilation techniques that were developed for synchronous programs to polychronous programs. This transfer is nontrivial because the underlying paradigms differ more than their names suggest: since synchronous systems react deterministically to given inputs in discrete steps, they are typically used to describe reactive systems with a totally ordered notion of time. In contrast, polychronous system models entail a partially ordered notion of time, and are most suited to interface a system with an asynchronous environment by specifying input/output constraints from which a deterministic controller may eventually be refined and synthesized. As particular examples for the mentioned crossfertilization, we show how a simulator and a verification backend for synchronous programs can be made available to polychronous specifications, which is a first step towards integrating heterogeneous models of computation.
Document type :
Journal articles
Complete list of metadata
Cited literature [43 references]  Display  Hide  Download
https://hal.inria.fr/hal-00763317
Contributor : Thierry Gautier Connect in order to contact the contributor
Submitted on : Monday, December 10, 2012 - 3:07:56 PM
Last modification on : Friday, February 4, 2022 - 3:23:15 AM
Long-term archiving on: : Saturday, December 17, 2016 - 11:33:07 PM
File
tse12.pdf
Identifiers
  • HAL Id : hal-00763317, version 1
Citation
Jens Brandt, Mike Gemünde, Klaus Schneider, Sandeep Kumar Shukla, Jean-Pierre Talpin. Embedding Polychrony into Synchrony. IEEE Transactions on Software Engineering, Institute of Electrical and Electronics Engineers, 2013. ⟨hal-00763317⟩
Share
Metrics
Record views
305
Files downloads
213
