Cardiac Monitoring of Marathon Runners using Disruption-Tolerant Wireless Sensors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In most current biomedical monitoring applications, data acquired by sensors attached to a patient are either transmitted directly to a monitoring console for real-time processing, or they are simply recorded on the sensor unit for deferred analysis. In contrast collecting and transmitting biomedical data continuously over long distances in outdoor conditions is still a challenge. In this paper we investigate the possibility of using disruption-tolerant wireless sensors to monitor the cardiac activity of runners during a marathon race, using off-the-shelf sensing devices and a limited number of base stations deployed along the marathon route. Preliminary experiments conducted with a few volunteers running around a university campus confirm that this approach is viable, and suggest that it should scale up to a real marathon.
ucami12benferhat.pdf (599.03 Ko) Télécharger le fichier
hal-00763319 , version 1 (10-12-2012)
  • HAL Id : hal-00763319 , version 1
Djamel Benferhat, Frédéric Guidec, Patrice Quinton. Cardiac Monitoring of Marathon Runners using Disruption-Tolerant Wireless Sensors. 6th International Conference on Ubiquitous Computing and Ambient Intelligence (UCAmI'12), Dec 2012, Vitoria-Gasteiz, Spain. pp.395-402. ⟨hal-00763319⟩
533 Consultations
381 Téléchargements
