Optimal algorithms and approximation algorithms for replica placement with distance constraints in tree networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we study the problem of replica placement in tree networks subject to server capacity and distance constraints. The client requests are known beforehand, while the number and location of the servers are to be determined. The Single policy enforces that all requests of a client are served by a single server in the tree, while in the Multiple policy, the requests of a given client can be processed by multiple servers, thus distributing the processing of requests over the platform. For the Single policy, we prove that all instances of the problem are NP-hard, and we propose approximation algorithms. The problem with the Multiple policy was known to be NP-hard with distance constraints, but we provide a polynomial time optimal algorithm to solve the problem in the particular case of binary trees when no request exceeds the server capacity.
Fichier non déposé
hal-00763359 , version 1 (10-12-2012)
Anne Benoit, Hubert Larchevêque, Paul Renaud-Goud. Optimal algorithms and approximation algorithms for replica placement with distance constraints in tree networks. Proceedings of IPDPS 2012, May 2012, Shanghai, China. ⟨10.1109/IPDPS.2012.95⟩. ⟨hal-00763359⟩
58 Consultations
0 Téléchargements
