Topological control for isotropic remeshing of non-manifold surfaces with varying resolution: application to 3D structural models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we propose a method to remesh non-manifold surfaces with triangles as equilateral as possible. We adapt an existing Voronoi based remeshing framework to recover the topology of non-manifold surfaces and their boundaries. The input of the procedure is a non-manifold triangulated surface constituted of several connected components representing geological interfaces (faults, horizons, detachments, etc). Positions of a given number of points are globally optimized to obtain an isotropic sampling of the surface. Then a topological control that enforces the topological ball property adds points to recover non-manifold edges and vertices. The method is demonstrated on a complex 3D fault model and clears the path for generating several models with varying resolution under topological control.
Automatique
Fichier non déposé
hal-00763409 , version 1 (10-12-2012)
Jeanne Pellerin, Bruno Lévy, Guillaume Caumon. Topological control for isotropic remeshing of non-manifold surfaces with varying resolution: application to 3D structural models. IAMG 2011 - Mathematical Geosciences at the Crossroads of Theory and Practice, Sep 2011, Salzburg, Austria. pp.678-688, ⟨10.5242/iamg.2011.0158⟩. ⟨hal-00763409⟩
122 Consultations
0 Téléchargements
